Aproximate Horsepower
Since I have not found any dynos here in Brazil, I would like to ask any of you experts in EVO's how much horsepower I have aproximately with the my current mods? The stock car is an EVO VIII with 280hp stock. Everything is stock, except for the mods below listed in my signature. I apreciate any response.
silverEVO8 there arent any good people to tune an EMS here, do you recomend a reflash? I contacted dynoflash but no response, I guess its because I am in Brazil. The car stock has how many WHP?
the ECU is stock, no reflash or EMS, just the cams, intake and axaust ...
. However, that's not necessarily true... Your car could be one of those that responds well to mods. BTW, the trick for more power is really to make more boost. Of course, tht can be very risky without a proper tune or very high octane gasoline.....
Originally Posted by silverEVO8
Just a guess, but probably 230~240 on a dynodynamics. Add about 13%~15% for a dynojet number. It's been my experience that without a proper tune, you don't get the power you could out of your mods.... Sometimes, it can actually hurt performance in some way. Like, if you get more lean mixture or higher boost from your mods, the car could detonate and the ECU will pull timing, which could result in less power
I don't know if this is a good idea for you, but if you had a way to do some datalogging and send those files to a good tuner, they can probably send you maps to try until you get close to a good tune. Of course, it could be a tedious and long process. I don't know if anybody would do it. Way back when I had my EVO VIII, the tune was completely screwed up by the guys who did it. Scot Grey was able to help me tune the AEM EMS via email and telephone, but it was a messy thing to do....
I think that if the XEDE can datalog, you could use it to collect data and send it back and forth to a good tuner to try different maps... You might try contacting Shiv at Vishnu or Andrew at Dyno4mance....Good luck
fsugatorbait, just fixed the EVO XVIII, hahaha, I did not see that until now ...
You think 300 whp? How much whp has the stock engine?
hahaha.
Yeah, with those parts untuned in the states on 93 pump you should be right around 300whp. Stock you would probaby dyno around 230whp.
Originally Posted by fsugatorbait
What the hell is an evo 18? You are probably around 300whp.
mistake until you mentioned, haha.
hahaha.
simple EMS?
