Why on the best motoring vehical the evo VIII revs to 8000K?
I have not seen it. Are they stock? Are they the JDM EVOs in the vidios? Doesn't the JDM EVOs rev to 8000 RPM? But I didn't think that the JDMs were up to 8 yet. This is confusing though. I thought the JDM models were one behind in terms of numbering.
JDM 7 = USDM 8 ?
JDM 7 = USDM 8 ?
The cd is wieord. I computer cant' read it. "no disc detected" However, i was able to get it running on my VCD player since my dvd player wouldnt' read it.
It's .99gigs per file
Oh it's like $13 from ebay. It takes like 5 days to recieve.
to answer your question....try it in your car.... it won't shut off until about 7900rpm...... I plan to drag race my car soon, and will experiement in shifting closer to the shut off vs the redline.... we'll see.... it may drop way off in power by then, but.???
Originally posted by value
If you video is a DVD the reason you can't read it is Japan has different coding for DVD's. Make sure you get VHS next time.
It's in different region too.
I power shifted when the car dies down around 6500-6700 i only seen it rev to 7000 rpms? Usually it free revs to redline when i do that but i wonder if there is a cutoff while no load or if i could really shift that fast
What does that mean? I thought the max rpms for our 4G63 is 7 grand. I guess the evo's version does close to 8000 rpm and we just need some ecu tuning to take advantage of our hi performance engine.
