1.8 60 ft 13.9?
Old Apr 29, 2006 | 04:04 PM
SPOOLEDTSiAWD's Avatar
1.8 60 ft 13.9?
I am having a bit of a problem. I went to the track yesterday with hopes of hitting somewhere deep in the 13s. I was badly mistakin. The fastest time I pulled the whole night was a 13.9 but had consistent 1.8 60 fts. I was forced to shift early at 6500 in 3rd and 5500 in 4th. At those points, the car just wouldnt accelerate. Does anyone know what could be the problem.
By way, my mods are as followed
Vishnu Stage 1+(Dealer reflashed it to stock before I bought the car...Could this be the problem?)
272 Intake cam/264 Exhaust cam
3" tbe
Thanks in advance.
Old Apr 29, 2006 | 04:06 PM
darthfoul's Avatar
I'd suggest getting on the dyno and getting a good idea of whar your AFR's are at, and TUNE! It makes all the difference in the world. Try that and see if it helps your times.
Old Apr 29, 2006 | 04:12 PM
w evo's Avatar
so you have cams but dont have a flash... you need a tune
Old Apr 29, 2006 | 04:15 PM
SiCKlEyWiKeD's Avatar
+1 on the tune. Cams + no tune = slower car sometimes.
Old Apr 29, 2006 | 04:19 PM
SilverShadow03's Avatar
Yeah.....tune it and then take it back to the track. My properly tuned Stage 1+ is killer. I haven't taken it down the 1/4 mile yet but will soon. You'll notice a big difference.
Old Apr 29, 2006 | 04:49 PM
Appreciate it. Well for the actual tunig, I dont have anything to actually tune it. Will a new v390 flash be just as good?
Old Apr 29, 2006 | 04:50 PM
3volution8's Avatar
with those mods plus a tune you should make it into the 12's easy with your 60ft time
Old Apr 29, 2006 | 04:52 PM
Stinkapuss's Avatar
Fuel pump?
Old Apr 29, 2006 | 05:03 PM
Originally Posted by Stinkapuss
Fuel pump?
Are you askin what kind it is?
Old Apr 29, 2006 | 05:04 PM
brandon's Avatar
i have had two evos that for reasons i dont care to get into have had cams in and had to reflash it back to stock and can tell you right now that your car is running on its second map (pulling timing and blah blah) and not even running where a stock evo would. so get it flashed for your mods and be prepared to enjoy something badass.
Old Apr 29, 2006 | 05:06 PM
The excitement is starting to build!!!
Old Apr 29, 2006 | 05:09 PM
stiguy's Avatar
Tune!
Old Apr 29, 2006 | 05:34 PM
bluebyu36's Avatar
get your 60 foot time down a little and dont run it agian with out a tune
Old Apr 29, 2006 | 05:37 PM
I dont plan on runnin it till i get a tune. I own a DSM also and it sucks when somethin breaks
Old Apr 29, 2006 | 05:39 PM
Stinkapuss's Avatar
Do you have a walbro or you still using the stock pump?
