for those with T-Bolt clamps.....
for those that using T-Bolt clamps what sizes do you need?? i want to replace my clamps just to be safe because i hear of people's hoses popping off or whatever and I don't want that happening so I want to change all the clamps to T-Bolt. what sizes do I need?? I tryed searching but couldn't find anyone that stated the sizes needed. Thanks In Advance!!!
Took 10 seconds to search and found this.
Lazy ***
https://www.evolutionm.net/forums/at...chmentid=86114
Lazy ***
Originally Posted by Cajun Power
OK I think we are still missing a few spots.
I have attached the drawing of the complete system. There are 12 clamps needed and 1 optional. I say optional because it never sees the boost level. That is the one on the BOV outlet to the intake pipe before the turbo. If that leaks who cares.
Starting from the turbo on the diagram:
1. Turbo outlet pipe to Air Hose A size-2.0"
2. Air Hose A to Air Pipe A size-2.0”
3. Air Pipe A to Air Hose B size-2.5"
4. Air Hose B to Charge Air Cooler size-2.5”
5. Charge Air Cooler to Air Hose C size-2.5”
6. Air Hose C to Air Pipe B size-2.5”
7. Air Pipe B to Air Hose D size-2.5”
8. Air Hose D to Air Pipe C size-2.5”
9. Air Pipe C to Air Hose E size-2.5”
10. Air Hose E to Throttle Body size-3.0”
11. Air Pipe C to Air By-pass Hose size-about 1.5” not sure.
12. Air By-pass hose to By-pass Valve size-about 1.5” not sure.
13. (Optional) By-pass Valve to Air Intake size-about 1.5” not sure.
The 5 listed by AfireINSIDE (post #18 above) are #’s: 5 thru 10.
If anyone can post the correct sizes on the missing pieces I will update so we can have a good list for people.
Updated 3-10-06 (found the turbo outlet size.) Just need the BOV sizes.
I know where to look....
oops.. copy and then paste.... LOL
https://www.evolutionm.net/forums/sh...d.php?t=193838
