evo engine automatic
Old May 1, 2006 | 07:43 PM
ralliartevolll's Avatar
switch the clutch and gas so you use opposite feet for gas and clutch, imgaine that i bet it get the job done. when i had a broken leg i got cabin fever went nuts and rigged up some push rod type thing to the clutch pushed it in with my left hand turning and shifting was tricky but when your stuck inside for a few months times get desperate
Old May 1, 2006 | 07:47 PM
azredevo's Avatar
Originally Posted by shiftdsm E
look up lancer evolution VII GT-A, its an automatic evo with no vent in the hood. It was supposed to be more civil, for the mature "enthusiast"
http://media.mitsubishi-motors.com/p...detail287.html
"GT-A uses Brembo 17-inch ventilated discs with 4-piston calipers at the front and 16-inch ventilated discs with 2-piston calipers at the rear that deliver positive stopping power, with low fade and high control characteristics in all modes - from urban cruising to full-bloodied competition driving." 17 inch discs w/ 16 in the back?! a tad ginormous, isn't it?
Old May 1, 2006 | 07:52 PM
mikejam1688's Avatar
stupid paddle shifter..i think its lazy
Old May 1, 2006 | 07:57 PM
Evolved Monkey's Avatar
Its definately posible to fit an Automatic transmission into the Evo, but the problem is cost ( tranny, ecu, install) and the fact that the X would come with an Auto as an option.
Old May 1, 2006 | 07:58 PM
GPTourer's Avatar
Those brake diameter listing have to be a misprint. The GT-A had a smaller turbo and/or less power, it would not then have bigger brakes, and even so not that big. 17" rotors will not fit behind 17" wheels.
Maybe an Outlander AWD trans can be swapped in place on a U.S. Evo. After being beefed up of course.
Old May 1, 2006 | 08:04 PM
11secEVO7's Avatar
the evo 7's game in a GT-A model which were tiptronic
Old May 1, 2006 | 08:06 PM
azredevo's Avatar
Oh, I know, it's just funny a misprint in an official Mitsubishi statement could have gone unchanged for so very long.
Old May 1, 2006 | 08:07 PM
evofan@scorp's's Avatar
I shall ***** this link yet again....http://www.theevo.com/
Old May 1, 2006 | 08:20 PM
josh1423's Avatar
thank you guys i might just wait for the x
Old May 1, 2006 | 08:31 PM
TheGVR4kid's Avatar
Scooter on here own an evo, autocrosses the **** out of it, and only has 1 leg.
A determined individual can do anything.
Old May 2, 2006 | 04:37 AM
josh1423's Avatar
only reason im lookin into this is i got a deal on my lancer and i like the style so im curious in the possibilities
Old May 2, 2006 | 05:18 AM
Waz996's Avatar
there are a few GTA's here.. but none i found was for sale..
Just to tell u that it really exists!
wael
Old May 2, 2006 | 05:36 AM
EVOeight's Avatar
4. Driveline
GT-A uses the INVECS-II Sport-Mode 5-speed automatic transmission that has been honed and refined to perfection in the Mitsubishi Galant VR-4. Gear ratios have been optimized for GT-A.
On GT-A, Sport-Mode enables the enthusiast driver to shift through the gears using either the manual gate or, for the first time in a Mitsubishi car, thumb-operated selectors located on the lateral spokes of the steering wheel.
GT-A features Mitsubishi's own all-wheel control system comprising ACD (Active Center Differential), AYC (Active Yaw Control) and Sports ABS components that bring dramatic improvements to dynamic performance. Optimized for the automatic transmission, these advanced components bring easy- and fun-to-drive performance to a wider range of drivers.
