problem with this
Old May 4, 2006 | 11:19 PM
armympjch's Avatar
problem with this
i will be completely honest. i dont really know much about what i should do. i have read some and im getting ideas. i know that alot of people say that the Injen intake and upper incooler pipe isnt a smart idea. i know this now..... but its already on. i have a EVO IX MR. i have a Injen Short Ram Intake with the upper inner cooler pipe(yes i am kind of regretin it now) installed already, BUT i ALSO have a 3'' RnR TBE w/ a high flow cat, walbro fuel pump, perrin fuel rail, Forge UNOS MBC, HKS TT and harness. this stuff is waiting to be installed cause im not doin it myself. i have about another $2,000 - $2,500 to spend. i was wondering if i could get some ideas from some of you without being talked bad about because of my choice with the Injen stuff. also i know that i will need a reflah afterwords. i am keepin that in mind. i live in alaska and i dont think that anyone here is able to custom tune EVOs thats why imjust goin to use a reflash until i leave alaska. but what are some performance things that i should get? thanks for any help.
Old May 4, 2006 | 11:23 PM
Warrtalon's Avatar
Man, why not go search first to learn the answer to this question? You made the mistake of not searching before buying the Injen and now you're making the mistake of not searching again.
You need an LICP, o2 housing, and flash, then you should save the rest for a clutch + install.
