Attn: IX owners....
Old May 8, 2006 | 12:12 PM
Phizix's Avatar
Attn: IX owners....
Have you guys/gals had any problems with an mbc? like not holding boost? thanks
Old May 8, 2006 | 12:54 PM
TeStUdO's Avatar
If you buy a good MBC like a Hallman or a Forge and install it properly you wont have a problem. Try a search there is a ton of info on the subject.
Old May 8, 2006 | 01:20 PM
Rnm's Avatar
Rnm
There is still taper thanks to MIVEC. I am hitting 22psi and settling down to 18psi with the Forge UNOS.
Old May 8, 2006 | 01:41 PM
Phizix's Avatar
thanks, thats what i was looking for. Do you or anyone else happen to know why the MIVEC effects the mbc like that?
Old May 8, 2006 | 03:00 PM
zgodfathera's Avatar
bump....
Old May 8, 2006 | 03:39 PM
DahakaJR's Avatar
23~19. Hallman, it's normal.
Old May 8, 2006 | 05:28 PM
Wrath's Avatar
I got my MBC from buschur, holds boost solid at 22psi with only about 1psi of taper the few times when it does move.
Old May 8, 2006 | 05:33 PM
pog0's Avatar
My HKS EVC 4 holds boost solid on my gauge. It's set to 20.5 psi. Map sensor reads 20.5-21 psi and tapers down to about 18 psi.
Old May 8, 2006 | 06:16 PM
Rnm's Avatar
Rnm
Thats got to be the best of any IX holding boost. I'm certain if boost was read by the map sensor, it would show more taper than that.
Old May 8, 2006 | 06:31 PM
Warrtalon's Avatar
RNM, he isn't really only dropping 1psi. People say that all the time, but it's not really true. If you put a MAP sensor on their car and measure the actual boost, you'll ses a linear reduction in boost from peak to 7k rpm, and that reduction will be more than 1psi.
Old May 8, 2006 | 06:43 PM
Jhero23's Avatar
My IX boost to 22-23 tapers to 19, no manual boost controller...priceless
