stock boost for a IX
Old May 12, 2006 | 02:33 PM
Silver06evo9mr's Avatar
what does the evo IX run for stock boost? is it supposed to be 20.3?
Old May 12, 2006 | 04:18 PM
Warrtalon's Avatar
20.3psi peak at 3500rpm
17.x psi taper at 6500rpm
Old May 12, 2006 | 04:26 PM
Wheelhaus's Avatar
that's not for every gear, is it?
This is sort-of related and I haven't been able to find a real reason.. and I can't remember how the car acted before the parts were installed...
With a MBC/catless TBE, why do higher gears hold more boost? 6th gear pulls 21.5 at most, but the lesser gears don't come close.
Old May 12, 2006 | 04:36 PM
Warrtalon's Avatar
Wheelhaus, you're seeing more boost in higher gears due to there being more load. It's standard.
Old May 12, 2006 | 04:42 PM
zgodfathera's Avatar
so this would be 3rd gear pull?
Old May 12, 2006 | 04:51 PM
Warrtalon's Avatar
Mitsu doesn't state which gear, but it would be 3rd gear or higher.
Old May 12, 2006 | 05:45 PM
andenbre's Avatar
mine does some odd stuff, like if its not warmed up completly it will cut boost down to less than 1 bar under load. has any body else experianced this?
kinda embarassing, I took a friend from work for a ride at lunch and every time I got on it, it would hit approx 19 psi then cut to 13 or so. I dont think it was fully warmed up and I figured it was a bad tank of fuel cause I filled up with shell premium at a station that just changed over from bell fuels to shell. however after I filled up with bp amoco ultimate it still cuts boost if I dont have at least 5-10 min of drive time in
Old May 12, 2006 | 05:48 PM
Wheelhaus's Avatar
That's kind of what I figured, but I could never find anyhting difinitive. Thanks.
Old May 12, 2006 | 05:50 PM
Wheelhaus's Avatar
Mine does that as well. You don't want to start railing on a cold engine and the ECU knows that. Save your engine and turbo, wait until it's fully warmed up.
Old May 12, 2006 | 05:58 PM
Thanks your the man.....once again
i hate to admit it tho...
moey124
Apr 14, 2008 10:40 AM
AZ EVO IX MR
For Sale - Cars For Sale
10
Mar 26, 2008 08:59 AM
rallykid
Mar 23, 2007 11:33 AM
evolrobert
11
Sep 14, 2006 05:42 AM
AZ EVO IX MR
Sep 10, 2006 08:07 PM
