greddy titanium question
Old May 15, 2006 | 06:43 PM
white venom's Avatar
Question greddy titanium question
i was reading on myevostore.com and it states" 2006 Evolution Installation Issue: This exhaust requires an o2 sensor plug in order to be installed. In 2006 Mitsubishi USA placed the o2 sensor on the catalytic converter instead of on the cat-back mid-pipe." so would i have to by an additional part?
Old May 15, 2006 | 06:45 PM
NocturnalEVO's Avatar
you would just need an 18mm plug for the o2 sensor bung.
I have the greddy ti on my 06 MR.
Old May 15, 2006 | 06:46 PM
you can find 'em on ebay, ATP turbo has them, and so does Cal @ Speed Element as far as I know
Old May 15, 2006 | 06:54 PM
is it just a plug for the hole in the piping so it wont leak??
Old May 15, 2006 | 06:58 PM
http://cgi.ebay.com/ebaymotors/18mm-...ayphotohosting
Old May 15, 2006 | 07:02 PM
Tsurugi-san's Avatar
WORKS Exhale cat-back uses the 18 mm plug also.
Old May 16, 2006 | 03:42 AM
MR 600's Avatar
I did not buy anything, i just installed my stock 02 sensor on to the greddy Ti exhaust plug. no CEL yet. and did not need to plug anything (used stock 02 as plug)
Old May 16, 2006 | 08:01 AM
res04's Avatar
IX needs to plug the hole, VIII does not. IX sensor is in the cat vs. cat back on VIII's.
Old May 16, 2006 | 12:58 PM
MR 600's Avatar
If your only changing the cat-back, then yes you have to plug it. i went with the DC DP which delets the cat and has no plug on it at all. so i had to move the 02 sensor down and bolt it on the greddy catback.
hope this clears things up.
Old May 26, 2006 | 12:17 PM
will another o2 sensor from a lincoln navigator fit until my cat delete pipe comes in?? I am in the proccess of installing it at the moment
