HELP diagnose a problem
Old May 19, 2006 | 02:00 PM
supravital's Avatar
The problem is a sound that comes from the front end of the car when braking...when i slightly push the brake there is no sound..but when brake is fully applied there is a single knock..sometimes the sound comes from the driver side and sometimes the passenger side..this happens during normal driving between 25-35mph....the brake is not pressed hard for the abs but enough to stop the car at a light or stop sign..please help thanx....
Old May 19, 2006 | 02:03 PM
Ph3n1x's Avatar
Dead Cat or Dog?
lol
jrsimon27's Avatar
loose intercooler or radiator or check the suspension first
Old May 19, 2006 | 02:06 PM
supravital's Avatar
ill check that..thanx..another thing is that the knock is hard enough to feel it on the floor under the pedals..also the knock is only when braking...if this helps..thanx
Old May 19, 2006 | 02:14 PM
res04's Avatar
More often than not this will be the DP hitting one of the braces IF you have a aftermarket DP. While the car is still it looks like you have clearance so 'it fits' but under braking and acceleration the factory motor mount makes quite a bit of movement and can allow the pieces to make contact creating a tapping, banging noise on occasion.
I chased my same noise down forever, checked brakes, checked suspension etc. but it was the hitting of those pieces.
Pull one or both of the braces off then go drive and see, takes only a few minutes to do.
If its the cause, add one or two thick washers to space out on all 5 areas of all braces.
Old May 19, 2006 | 02:15 PM
res04's Avatar
That noise I had sometimes seemed to come from the brakes, sometimes left, sometimes right, sometimes from behind the firewall......it was very misleading for the most part.
I will also add if your DP is stock then check the motor mount, might be bad.
Old May 19, 2006 | 02:18 PM
tbplayer45's Avatar
+1, Just what I was thinking.
Old May 19, 2006 | 02:20 PM
res04's Avatar
Checklist:
Rubber spring isolators may have shifted (common)
Rubber spring perch damaged
Rock, debris on top of front spring (it collects lots of crap, youd be surprised)
front sway bar lose
sway bar end links bad
DP hitting under bracing (common)
Brake pad shift (rare)
Stuck brake piston (rare)
Bad master cylinder / air in lines (rare)
Old May 19, 2006 | 02:21 PM
supravital's Avatar
thanx for the help....the knocking is exactly what u said...right side left side and maybe firewall....and i do have an aftermarket dp.....a 3in megan dp.....ill check that out....thanx alot...
brokeazzlos's Avatar
if you got aftermarket pads, some fit loose and make a clunk sound
mostly when going from reverse to foward
