just installed boost guage. 17psi?
Old May 25, 2006 | 04:12 PM
RallyRedRSIX's Avatar
My boost gauge is showing 17 psi at the most. There really isnt any tapering either. is the correct? i drive a IX if that makes any difference at all. Ive heard that every car is different.. or my boost guage is off.
Old May 25, 2006 | 04:16 PM
Warrtalon's Avatar
It probably is about right. They don't all come with full boost from the factory, and if you really are only seeing 17psi peak, I wouldn't expect it to taper at all.
I've seen a stock IX only register 1.1 bar on the dyno in stock form, then another stock IX was showing 1.4 bar on the same dyno same day. They made about 30whp difference in power, but that is easily remedied with the right mods.
There's also the possibility of a loose hose causing a boost leak somewhere or the gauge is off, but I'm more inclined to think it's just low boost from the factory.
Old May 25, 2006 | 06:04 PM
sandm's Avatar
mine did the same thing once I hooked up the boost gauge. 17psi dead on, no taper. installed a forge mbc and now I have 21-22 at full throttle in most gears, but once in a while it creeps up to 24 for a sec when in 4th or 5th at 4-5k and the gas is floored.
get a mbc and it will take care of all that.
then get a dynoflash
Old May 25, 2006 | 06:06 PM
sandm's Avatar
interestingly enough, my old 8 idled at around 17hg of vacuum when stock, but idled at 14 when I put in the hks 272's...The 9 idles at more like 15-14 all the time. wonder if that's the mivec intake cam?
Old May 25, 2006 | 06:26 PM
Rnm's Avatar
Rnm
I have a 9 and it idles around 18hg of vacuum near Sea Level.
Old May 25, 2006 | 06:46 PM
I feel stupid. I failed to mention it was 96 degrees outside when I ran... Ill wait till late and see if the denser air helps...
Old May 25, 2006 | 06:53 PM
sandm's Avatar
it didn't on mine. have driven it home on several cool days and still only 17psi.
Old May 25, 2006 | 07:01 PM
no.. Say things I wanna hear. =) . Well I like my warranty. Ill stick with 17psi till they say " blah blah, we can't cover that under warranty.. Because uh.. ". Thanks for the insight.
Old May 25, 2006 | 07:31 PM
Doogie Howser's Avatar
Anybody else getting some pretty sweet boost taper at around 5k? I see a spike of 21 and by 5k its 17 or 18 psi...
Old May 25, 2006 | 08:05 PM
shbomb8188's Avatar
i spike around 20-21 psi then quickly tapers to around 16-17 psi (bone stock) on my defi bf.
sandm's Avatar
all depends on the dealer. our mitsu dealer here will allow exhausts, intakes and boost controllers, but draw the line as soon as the motor is cracked into or standalone ems's are installed.
kinda nice to walk into the service shop and see a display of subaru and evo/eclipse exhausts hanging for sale(they are the suby dealer as well).
Old May 25, 2006 | 08:08 PM
sandm's Avatar
I see that now with my forge mbc installed, but it is the same response that I think you will see out of most stock turbo'ed evos.
prior to the mbc, I held 17psi from 3k all the way to redline steady...
Old May 25, 2006 | 08:12 PM
hmm I have a forge unos mbc
How much boost do you hold with the mbc installed?
Old May 26, 2006 | 11:45 AM
mdsevo06's Avatar
Fales advertising! Every brochure I've seen, has in writing 20psi. I remember back in 02, the Mustang Cobra advertised a certain bhp and fell short. They had to change the exhaust I believe, to hit the advertised mark. Not saying Mitsubishi would ever do anything about it, but if enough people showed 17psi at the dealer, maybe they would have to Flash the ECU to hit 20psi.
Wishful thinking I know...
Old May 27, 2006 | 12:01 AM
vwjeff's Avatar
Just because of this post I went out and bought a gauge today and installed it.
When I went and drove it after the install the gauge reads 17 psi from 3500 rpm and drops 16 at 7k. This was in 1 through 3, I didn't have enough road for 4 and 5.
I was thinking of adjusting the wastgate accuator rod, for the time being, anyone else tried this
Sorry but I have to edit this, I tapped the wrong location for the gauge.
It is accually 18, and 15 at redline..... sorry about that.
