transfer case whining.....
Originally Posted by 19.5PSI
i'm wondering too as to what kind of whining.
mine doesn't whine at all during acceleration. it does kinda when i have my foot very lightly on the gas, not enought to speed up but to keep it going at a slow speed.
Same here...I was thinking this is normal. Because the other 2 evolutions I test drove was the same way,,,but that doesn't mean anything either.
If someone could chime in, that'd be great. Because when one person says "whine" , it may mean something totally different to another.
I have 70k on my evo. My first tcase was replaced around 37k. I had and still have a small whine at 60mph~. Car pulls great. Indication that my first tcase was going out had a much louder distinctive whine from low mph to high. When you are at high speeds, that tcase should be singing pretty loudly if it is going out. Also, you should be hearing a louder sound while slowing down too. Another way to check your tcase is to pull out the drain plug. Check to see if there are metalllic pieces in the oil, or stuck to the plug. If you have shavings, then you probably have problems. It might be worth your time to drain the tcase and check it.
FYI- you should be changing out your differential fluid every 15k.
if not sooner based on your own wear and tear.
the sound is very similar to a tornado warning...it's loud...very loud.
i'm still rockin' my whinning tcase. i've put 1000 miles on my evo since it started whinning.
so when it does eventually go out...what should i expect? like does it lock all 4 tires while im driving?
so far the whining is noticable only at slow speeds (10-25mhp). i don't notice it at higher speed but maybe that's because everything else about the car is loud. the whine isn't too loud either, only if all windows are shut and the radio off would you hear it. it's almost like when the window of your house is cracked open on a windy day. the first time i changed my tc fluids, i did notice some fine metal pieces but i have heard that it's normal in a new car. the second time i changed it there were none (metal pieces) so i guess it's ok. maybe i'm just paranoid.....i do freak out when i hear something i'm not used to hearing.
Originally Posted by evo150
when at speeds of 65-85 i would describe my sound (dont believe its the tc) as a faint whistle but only happens when i slightly press on the gas (still in vaccum on the gauge but not in boost). this only happens in 5th gear. i think i will put my stock intake on and see if it fixes the whistle sound, unless someone here can let me know what it is.
could you explain a little more in detail on how you got this fixed under warranty...i also have an act clutch...i put the rest of my car back to stock and i take my car in to have them look at it friday.....
-nick
-nick
Originally Posted by BBYBruno
I know there not but you need to be persistant. At first they were like haha no way, "you have an aftermarket clutch which caused the problem". So I had them bring the district rep to the dealer so I could speak with him. I gave him the facts on how my ACT had nothing to do with my failing TC which I obtained from ACT and Shep.
So basically the district rep made me put the stock clutch back in before he would honor the repair.
My mods at the time were TBE, MBC, intake, flash, ACT.
They replaced the TC, rebuilt tranny and new synchros.
-nick
-nick
Then if the service guys don't do anything for you, request to speak with the district rep in the area, or set up a time were he can come out to look at your car.
If you still have your ACT in at the time he looks at your car, he will probably tell you to return to stock clutch before he honors any labor/parts.
So I basically went on evom and bought a 3500k used stock clutch for $150 and then I got all my labor/parts under warrenty.
-nick
-nick
I had to **** and moan and fight, but I got it done. It helps if you had a lot of service work done at Mitsubishi. Also, if you have not changed the fluid any time recently, I would change it before you took it in for warranty if you havent done so recently. Dont let them see old fluid, they could use that against you as well. As mentioned before, they may have to contact the district rep.
Originally Posted by TTP Engineering
Ours whined at 82mph with the 6sp. Now it whines in 1st gear and a little bit of 2nd on the 5sp. ACT XTSS clutch I think has contributed to it.
