Evo IX vs. STI aerodynamics
Old Jun 7, 2006 | 08:31 AM
CGs's Avatar
CGs
Originally Posted by honda-guy
maybe the reason why the sti had more rear end down force is because it had more lift on the front end which transfer the car's weight to the rear. just a thought.
I don't a lot about this stuff, but if I remember my physics -- downforce from a wing is causes from air moving over it .. which causes low presure under it, pulling the wing down. This is how an airplane wing works, just turned upside down.
So based on the pictures:
And:
It looks like the STI wing has more air running over the top of it, causing more low pressure under the wing, "pulling" the rear end down.
That's my best attempt at an explination anyway
Old Jun 7, 2006 | 09:01 AM
zgodfathera's Avatar
^ nooooo
Old Jun 7, 2006 | 09:39 AM
Eggy's Avatar
I want to see an MR being compared as they are always the ones that flaunt the aerodynamics.
Old Jun 7, 2006 | 09:51 AM
Ludikraut's Avatar
Yeah, I think that is definitely part of it. IIRC, Subaru also cleaned up the underside of the STi, so it should have better airflow under the car, which will greatly contribute to downforce. Looks like the Evo still suffers from the "parachute" effect of the rear bumper at high speeds. It would be great to see an Evo tested with all permutations of vortex generator/splitter/rear undertray.
Great find on the article, btw!! Cd of .383 ... ... much worse than I thought it would be.
l8r)
Old Jun 7, 2006 | 09:52 AM
4WS Tuning's Avatar
so ur saying both cars are like pushing bricks through air? lol
Old Jun 7, 2006 | 09:59 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Originally Posted by byron3636
It has to work like that, unless you're willing to say those forces will actually make the evo's frame flex.
It doesn't have to. Theres no fulcrum in the center of the car. There would have to be some kind of pivot point to transfer the energy of the front lifting to the back. Instead the whole car just comes up. In this case, if anything, the fulcrum being the rear wheels.
As far as the wind traveling over the wing, it works the opposite. You want more wind under the wing traveling faster. Thats what creates downforce in the reverse fashion an airplane wing works.
Old Jun 7, 2006 | 11:03 AM
South Side Evo's Avatar
The 06 STI also has a rear diffuser, which helps the air exit the car with less drag. I'm not surprised by the higher frontend lift numbers of the STI, due to the huge hood scoop.
I am surprised by the rear lift of the Evo, compared to the unreal amount of down force of the STI. That also explains why the STI understeers at speed.
Looks like both cars can benefit from a well designed front spoiler (to reduce lift).
Old Jun 7, 2006 | 11:18 AM
fusionchicken's Avatar
wow...Cd of .383.........................
this is why more power is necessary
Old Jun 7, 2006 | 11:34 AM
jnathan68's Avatar
Little Knowledge Dangerous?
Well, a few things -
1) I remember seeing or reading in one of the Evo IX articles that an option for the Evo IX was a "Zero Lift" kit created by using a slight front "diffuser" and some other diffuser added to the rear wing. I am not sure about what makes up the kit but this is what I read (maybe what is used on the MR). I am guessing that the kit would reduce the lift to near zero.
2) It is my understanding that lift at high speed is not a good thing and that you would rather have some downforce holding the car to the road. I was kind of assuming the Evo would have more downforce than what is shown. Also curious if removing the rear wing hurts or helps (or doesn't matter).
3) Just happened to pick up the newest issue of Sport Compact Car magazine and noticed they are starting a series of articles on aerodynamics as related to cars. Anybody who wants to have a concept of the diagrams that started this post should pick up the issue.
Just my few cents!
Old Jun 7, 2006 | 11:35 AM
speedomodel's Avatar
Originally Posted by perfectevo
No vortex generator on the Evo IX. It would be interesting to see how much that changes things.
Or wickerbill. Interesting stuff.
Old Jun 7, 2006 | 11:37 AM
PhoenixEvo's Avatar
good information!!! Props on the post
Old Jun 7, 2006 | 11:50 AM
chenc544's Avatar
There are many factors that determine the lift or down force of an airfoil/wing. Factors such as thickness ratio, aspect ratio and camber are physical attributes of an airfoil. In an automotive application these factors are probably very similar between similar vehicles like the Evo and STI. The other two major factors are airflow condition and angle of the attack. An airfoil can generate more lift/downforce in a laminar (smooth) flow vs turbulent flow. Looking at the pictures it would appear that the STI’s rear aerodynamic maintains a more laminar flow while the airflow over the Evo’s rear is starting to separate. I guess the little winglet on the STI is doing it’s job.
Old Jun 7, 2006 | 11:53 AM
zyounker's Avatar
Thats still a mazda.
https://www.evolutionm.net/forums/at...chmentid=91484
Old Jun 7, 2006 | 12:11 PM
SoR's Avatar
SoR
One of my neighbours got a brand new STi and I couldn't help myself but crawl underneath and check out the underside. Was surprized to see the rear diffuser and car seemed cleaner than the Evo. They really did a good job.
Not sure why Mitsu didn't bring all those things to US from the JDM models.
Old Jun 7, 2006 | 12:22 PM
deffro's Avatar
Vortex generators dhould change things a good bit. The air is going over the wing much cleaner on the STI due to their upper windshield wing thing which does the same thing as the VG on the Evo. The Evos flow should be much better with the VG
