Changing Cigarette lighter bulb! HELP!
Old Jun 9, 2006 | 07:02 PM
dL_EVO's Avatar
I need help changing my cigarette lighter bulb. I've seen the instructions mrbttk1 and the rest is good except the cigarette lighter part. It's ultra vague..
I've taken the ashtray out, taken the black screw out, taken my shift knob out and the piece won't come out!!!
" Cigarette lighter ring: to remove the plastic grey part, take your ashtray out and take out black screw directly beneath it. Remove shift knob, and you can take out the plastic part to access bulb. "
that's what it said..
maybe i'm missing something, but can someone help me and break it down. THANKS!!
I own a EVO IX if that helps..
Old Jun 9, 2006 | 07:22 PM
dL_EVO's Avatar
nevermind, I figured it out...
Old Jun 9, 2006 | 07:27 PM
Cajun Power's Avatar
ok
Old Feb 22, 2008 | 10:35 AM
sdfontanini's Avatar
How do you change the bulb?
Old Feb 22, 2008 | 12:36 PM
Wallesasuaz's Avatar
u gotta remove your center console and flip it, and you'll be able to reach to replace.
Old Feb 22, 2008 | 04:00 PM
cool, that's what I thought. Some people are saying you remove one screw in the ashtray and remove the shift knob, then remove the top plastic piece. I'm pretty sure that's a crock of sheit.
Old Feb 22, 2008 | 04:04 PM
heel2toe's Avatar
I actually got to my ashtray bulb by doing that. The gray panel needs to be pryed up. There are clips all along the side. It was tricky to get to the bulb this way but if you can fit your hands in there its doable.
Old May 23, 2011 | 08:23 PM
shangai's Avatar
bulb type on it?
Old May 23, 2011 | 08:25 PM
Unrivaled's Avatar
Originally Posted by shangai
bulb type on it?
74
Old May 23, 2011 | 08:32 PM
Uryelowducky's Avatar
Quick question relating this thread. My cigarette lighter ring light is off and so is the one inside the ashe tray. Now is a fuse powering these lights up that probably broke? Or is the lights themselves broken? I just noticed it one day out of the blue that it wasnt working..
Old May 23, 2011 | 08:41 PM
shangai's Avatar
same problem as me and other, it should be the bulb.. you can use the one on th hvac to test them..
any idea wish one uses the ignition key?
Old Nov 11, 2011 | 08:21 PM
Tevo9K's Avatar
Does anybody know anywhere to buy these bulbs??
i went to pep boys, orally, auto zone, and summit racing and they did not have this size bulb nor did they have the color cover for them..
any help would be most appreciative!!!
Old Nov 11, 2011 | 08:34 PM
HN7's Avatar
HN7
I had to get mine at dealer, $3 a bulb I think.
Old Nov 11, 2011 | 08:54 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Eh, I replaced mine with LEDs.
Brighter light and they last a bajillion times longer than any incandescent bulb.
You can get them for like $1 a piece from superbrightleds dot com.
Old Nov 12, 2011 | 01:36 AM
Tevo9K's Avatar
hey can u help me out man?? i don't know the size or exactly what I'm looking for >_< can u possibly write up the link for me for superbrightleds?? I'm also looking for amber colred ones also thanks a bunch man!!
