Methanol-vs-Water injection
water absorbs more energy. alcohol cools better though as it has a lower latent heat of evaporation which means basically ALL of it is vaporized which maximizes cooling. this is why you see big torque jumps with alcohol.
both alcohol and water increase effective octane as they both absorb heat that would otherwise go towards predetonation.
alcohol is used additionally as a fuel which is where water doean't and hence is just a heat sink.
if you are worried about your injection system failing running water is just as bad as running alcohol. if you don't have the proper fail safes built in... you're running against the clock.
you can use safc to store different maps and then just take the whole extension harness out when you go in for work. good luck hiding your alcohol fuel cell though.
Originally Posted by MRinChrist
Is there a company providing ECUs mapped?...I understand they exist for flashing your existing ECU, but the only company I know selling mapped ECUs is RalliArt, and I do not think they do customized ECUs.
If this solution does not exist, there is a hole in the market. This whole "send your ECU" in and wait around thing needs a better solution....If I was a tuner, I would find a cheap way to provide pre-mapped and customized ECUs.
Originally Posted by trinydex
there is just about no way to give someone far away a customized ecu. this is why you use a piggyback that can store a real rudimentry map. a piggyback that you can unplug easily at any time.
i would rather run ecu+. mainly cuz the tech is better as you've brought up. also because you can hide it so no one sees (cubby behind ecu). other than the physical unit and the extension harness... it's invisible. you can zero it out no prob.
you guys really need to check this out...... it can save you alot of money
https://www.evolutionm.net/forums/sh...d.php?t=201146
