White Rabbit?!?
Old Jun 12, 2006 | 05:57 PM
MonsterEVOO's Avatar
White Rabbit?!?
Well Today i talked to Ams and i was asking them about there 50Trim... And they told me about a turbo kit Called White Rabbit from Forced Performance ... i dont know if i miss heard them.. But i cant find it anywhere on the Site.
Old Jun 12, 2006 | 06:00 PM
sasquatch's Avatar
I believe the white rabbit was rendered completely obsolete by the new 20g turbo. If the rabbit interests you look at the 20g kits available.
Old Jun 12, 2006 | 06:16 PM
05Evolution8MR's Avatar
Here is the link to the white rabbit.
http://linux.forcedperformance.net/m..._Code=AllTurbo
Old Jun 12, 2006 | 06:21 PM
Thanks
Old Jun 12, 2006 | 06:30 PM
smokedmustang's Avatar
Do your research on that one!!!! I would go with the 20G-9.
Old Jun 12, 2006 | 06:31 PM
ForcedPerformance's Avatar
The EVO9 20g-5 is the best incarnation of this unit available at this time. Give Buschur a call, he is our distributor for this item.
Old Jun 12, 2006 | 06:52 PM
dsmfan95's Avatar
The Evo-9 white rabbit is much better than the old Evo-8 version. I plan to go with it eventually.
Old Jun 12, 2006 | 07:34 PM
sparky's Avatar
Isn´t the difference between the 20G-9-5 and the WR-9 purely semantic? If I´m not mistaken they are for all intents and purposes the same creature.
Eventually, myself, I think I´ll upgrade my TME to a WR-9-TME, eventhough a short while back I was set on getting a TME-9, now I want the WR´s 5-bladed compressor wheel inside the IX compressor housing spooled-up by a clipped TiAl turbine wheel spinning inside of a ported 10.5 turbine housing. I´ll bet I can order one from Buschur. Now, I just need the cash.
Old Jun 12, 2006 | 07:39 PM
EvoDan2004's Avatar
Originally Posted by sparky
Isn´t a 20g-9/5-bladed turbo the same turbo as a WR-9(If not, the difference must be insignificant)? Also, does the WR come with the lightweight turbine wheel of the TME? Or would that be a WR TME? I think what I´ll eventually get is a WR-9/TME, although originally I had wanted a TME-9, however now I want the TME-9 with the WR compressor wheel , which is a WR-9/TME, right?
one time a saw a cat run across the road. and this other time i tryed to catch it and got lost.
if you understand what i just said them i must miss read that post. if not there is a good hint for you to re type that. lol. wr/tme/9-5 light wheel 7-429er
Old Jun 12, 2006 | 07:41 PM
EvoDan2004's Avatar
ok i read it like 7 times. i understand it now. kinda.
Old Jun 12, 2006 | 07:44 PM
EvoDan2004's Avatar
Isn´t a 20g-9/5-bladed turbo the same turbo as a WR-9(If not... the difference must be insignificant)? Also, did the WR, in its original incarnation, come with the lightweight turbine wheel of the TME? Or would that be a WR TME?
I think what I´ll eventually get is a WR-9/TME, although originally I had wanted a TME-9, however now I want the TME-9 with the WR compressor wheel , which would be a WR-9/TME, right? I guess I can get what I want from Buschur
ok my gess would be if the w/r came with tme inturnals it would be a w/r/tme. so you are right.
i never hurd of tme-9 turbo. not saying they dont make one just saying i never hurd of one.
if w/r is what you want. then id say yes w/r/tme would be your winner. but look into the b/r 20g9-5 1st. you may change your mind
did i make sence. i dout it.
Old Jun 12, 2006 | 08:27 PM
sparky's Avatar
The TME-9, as far as I know, was a concept first proposed by Trinydex. I think it is basically a TME turbo, which has the lightweight turbine wheel, combined with the IX turbo´s improved compressor housing. Really, it is a cheaper way to get the same performance as the JDM IX turbo which has magnesium internals and is way expensive.
Old Jun 12, 2006 | 08:45 PM
althemean's Avatar
The WR was originally a TME based turbo to begin with. You had two options. Send in your stock core and have it upgraded or buy the WR outright with the TME internals. I suppose three options if you already owned a TME and sent it in for the upgrade.
Old Jun 12, 2006 | 09:50 PM
sparky's Avatar
Thanks for the info. I guess then that a TME-WR would be a redundancy, since as you pointed out, WR´s all come wth the TME internals. That makes it easier. I´ll eventually get a WR-9...but I still think that a WR-9 is the same thing as a 20G-9-5(except for the TiAl turbine wheel), or am I lost once again?
Old Jun 13, 2006 | 05:41 AM
althemean's Avatar
well....there really hasnt been any solid proof that the WR compressor wheel is what went into Buschurs 20g-9-5. But most of us speculate that is what it is. You are correct that it is not built on the TME internals. When Buschur tried that on his original 20g-8w/TME he had surging issues. There is nothing to say that would happen with the 20g-9-5 as no one I know of on here has tried that combo yet. I also think that BR turbo has a modified turbine wheel as well but you would have to double-check that one. I am 99% sure of it though.
