Raising stock headlight height
Old Apr 20, 2003 | 03:56 PM
RTW EVO's Avatar
not sure if this has been posted before but here goes...
I know alot of people were complaining about the height of the headlight beam... well i did some diging around in the engine bay today and found out how to adjust the low beam height...
if you look in the engine bay, just behind where the low beam is there is a white cap covering the height adjustment bolt... after some careful persuasion (meaning i ripped the dam thing off with a pair of needle nose plyers) the cap came off and revealed the bolt. I marked my garage with the current beam height and turned the bolt clockwise about 1/4 of a turn... it's day time out now but hopefully this will be a decent fix for some of us that live in the middle of no where..
this is a pic of the passenger side headlight ... u can see the bolt marked by the arrow... I tested the adjustment tool from inside the car and the height returned to my setting and not the factory.. so it should help out some of you
Old Apr 20, 2003 | 03:59 PM
evo1's Avatar
Re: Raising stock headlight height
if you look in the engine bay, just behind were the low beam is there is a white cap covering the height adjustment bolt... after some careful persuasion (meaning i ripped the dam thing off with a pair of needle nose plyers) the cap came off and revealed the bolt. I marked my garage with the current beam height and turned the bolt clockwise about 1/4 of a turn... it's day time out now but hopefully this will be a decent fix for some of us that live in the middle of no where..[
Genius if it works mon! Be sure to follow up after dark.
Old Apr 20, 2003 | 04:40 PM
trance's Avatar
well...i don't have a EVO but yesterday i chatted for about a hour with a dealer checking out the EVO.Now he showed me a funky lil thing that i didn't know the EVO had.H pushed a lil button on the dash and it adjusted the height.He said that it was a stock feature and all EVO's have it.Seems like a cool idea to me.When your in the city you can lower them and while on the open road you can raise them.Don't know if i'm babbleing here and you want to raise the beam height even higher but just thought i'd put this out in case
Old Apr 20, 2003 | 04:51 PM
RTW EVO's Avatar
yeah the problem is that the highest setting is still a little low for us country folk... for once i wish it was winter so i could test out the new height. It's 5:30 and still light out, oh well i'm sure it will work out fine
evo1's Avatar
We all know about the headlight adjustment feature ... however, many of us agree that the highest adjustment point should be a little higher, and the lowest adjustment point is just way too low. Therefore, the point of RTW EVO's post is that he is attempting to raise the highest point of headlight adjustement a little higher.
Old Apr 20, 2003 | 06:19 PM
Boosted's Avatar
sorry guys, but it doesnt move up much at all, maybe 1/4-1/6th the distance one click on the dial makes the lights move
Old Apr 20, 2003 | 06:23 PM
Boosted's Avatar
then it wont go any further, just spins the bolt
Old Apr 20, 2003 | 06:35 PM
Smoktout's Avatar
you guys know that your lights are only supposed to shine on the road right? they aren't meant to be focused on the horizon, that's what the high beams are there for. also, in a previous thread someone stated that the height adjustments should always be set to the highest and if you put weight in the trunk it should be lowered to compensate for the angle.
Old Apr 20, 2003 | 06:51 PM
flybyevo's Avatar
I think you have it correct Ben. Also if you have some heavyweights in the car such as me the driver that can also bring up the lights so you may have to lower them.
How did you do last week after Krispy Kreme?
Old Apr 20, 2003 | 06:56 PM
2Cool's Avatar
Couple of things, its a 10mm bolt, and you get maybe 1/2 turn = very small adjustment. Don't keep turning, or likely it will strip the adjuster and may end up being worse than you started. Most likely this is the fine-tuning bolt used by to make sure all the Evos have the same headlight alignment, and its limited for safety reasons.
Now if someone wants to take apart their headlights to see if you can tweak it more... be sure to post pics!
Old Apr 20, 2003 | 08:50 PM
jojo's Avatar
Okay guys. For the second time here goes--while looking down at the drivers side light, look at approx. the center light.
more or less behind it you will see a toothed wheel with a 60 degree angle to get to it. Place a phillips screwdriver right in the slot and turn clockwise. The low beam will magically raise. Trust me, I did this the first day I got the Evo. It is a little tougher to get to the right side on.
Good luck!
Old Apr 20, 2003 | 09:03 PM
jojo's Avatar
Here is a picture:
Old Apr 20, 2003 | 09:08 PM
Trbo Dad's Avatar
Can you take a pic from back a little further. It might be easier to figure out/see.
Thanks.
Old Apr 21, 2003 | 01:49 AM
Erik@MIL.SPEC's Avatar
So are you saying that adjusting the philips head bolt will raise both headlights, or just the driver's side?
Old Apr 21, 2003 | 03:00 AM
dilow's Avatar
I checked it out on my own car and saw the gears. There's one on each side, so both will not adjust at the same time.
