to do or not to do
Old Jun 19, 2006 | 07:48 PM
dustin03's Avatar
Exclamation to do or not to do
I am thinking of doing a 20g 9-6 upgrade how do you all feel about this? I have a 16g with the 9.8 hotside.
Over all will this be a good step foward of not.
Old Jun 19, 2006 | 07:49 PM
DCSilvrEvo's Avatar
NO I believe the 20G-5 blades made good power.
Old Jun 19, 2006 | 07:51 PM
el producto's Avatar
Good step forward or not..hmmm?
03 16g vs 20g....
You need a calculator?
Old Jun 19, 2006 | 07:52 PM
dustin03's Avatar
well if I needed a smart as# I would have made a phone call.
Old Jun 19, 2006 | 07:55 PM
Dr. SS's Avatar
lol
yeah dude, a 20g-9 with supporting bolt ons, cams, pumped, and tuned, you'll be safe from any bolt-on, cammed IX.
Old Jun 19, 2006 | 07:58 PM
moreryce's Avatar
ur looking at some good power... let us know wut you decide...
Old Jun 19, 2006 | 08:11 PM
dustin03's Avatar
well I have done some research and came up with this if you are going to run 28+psi then the 5 blade is the way to go but I plan on staying around 25 so I think the 6 blade will do.
Is there anyone here running the 20g 9 6 setup if so how do you like it?
Old Jun 19, 2006 | 09:12 PM
Warrtalon's Avatar
If you don't go for high boost, then the 20g-9-6 won't be any better than a stock turbo, and it may spool later.
You ask if anyone is running a 20g-9-6 without searching to find all the threads where all those people already talked about it? That confuses me.
Old Jun 20, 2006 | 06:11 AM
PVD04's Avatar
The TME turbo or a used White Rabbit will probably net you about the same peak power and more low end torque for a little less money. I'm going to be putting a White Rabbit with a ported manifold and ebay O2 housing on my 03 as soon as I get the manifold, O2 housing, and hotside back from being ceramic coated.
-Paul
Old Jun 20, 2006 | 06:00 PM
20lbsboost's Avatar
personally id go with a 20 g
