Evo IX motor oil
Old Jun 23, 2006 | 03:02 PM
cij911's Avatar
Originally Posted by LetItBreath
Its also right on the oil cap
10w-30 Mobil 1 (although 5w-30 should be great in really cold climates)
Old Jun 23, 2006 | 03:15 PM
TimDC2x's Avatar
If you arnet on the track every weekend, why wouldnt it last 5000 miles? Its still a 4 banger remember, not some overly complicated V12.
Old Jun 23, 2006 | 03:36 PM
coco's Avatar
+1
If you dont redline your car every chance you get and the air around you is relatively clean, 5k miles is not a lot.
Old Nov 6, 2006 | 01:50 PM
saiyanzzrage's Avatar
10w30, but make sure it ISNT synthetic, you will wreck your engine
Old Nov 6, 2006 | 01:59 PM
pao's Avatar
pao
Not to be rude but let's not forget the manual that came with the car. It answers a lot of basic questions, like the grade/type of oil to use, or the replacement # for the fog lamps. Then again not everyone has a copy of the manual, that's why forums exists
Old Nov 6, 2006 | 02:00 PM
pao's Avatar
pao
Correct-O! Mitsubishi wants you to use Fully Synthetic oil.
Old Nov 6, 2006 | 02:10 PM
lcakes05's Avatar
i just changed mine 5 minutes ago mobile 1 10w-30. 5 quart jug at wallmart for $22, $6 oem filter from mitsu
Old Nov 6, 2006 | 02:16 PM
ntwaddel's Avatar
Originally Posted by SlowCar
wow.....i got mine april2006 and there is barely 2000miles on it.
Its up to you, mobil1 in there should last till 3000miles
i'll be switching to dino oil for 1st oil change, got some blow by and hopefully that will break in the engine a bit more and lessen it
wow i got mine July 29th 2006 and I have 7100 miles
Old Nov 6, 2006 | 04:29 PM
barneyb's Avatar
Originally Posted by Earthen
I got my IX MR 2 months ago and 4500 miles already. Its synthetic oil, dont need to change till 5000 at first then you can push to like 7000 miles. Look in your manual, it has a maintenence schedule at different mileage.
Go check the service manual for the definition of severe service. It lists things like stop and go driving and driving in hot weather. Everyone here is severe service.
Old Nov 6, 2006 | 04:35 PM
TogueMonster's Avatar
Fck that free maintenance bs. I took my car in a few times and they didn't even use synthetic in the engine. In the manual, it says synthetic is recommended, if I'm not mistaken. Dealership oil changes suck.
Old Nov 6, 2006 | 06:01 PM
kouzman's Avatar
I changed my oil at 2000 miles and now i will change it again at 4000 miles... That's my interval... 350-40 the cost of oil is nothing compared to the well being of my engine...
My first oil change was the 10w30 mobil, but now i am thinking of using either redline, or amsoil, or Castrol Syntec... Another one that i am thinking of is the Motul 300V but i think its a 5w30, but i think that i won't have a problem because now its winter and i change it very often...
I will decide in a month or so when the time comes...
Old Nov 6, 2006 | 06:17 PM
Evolved Monkey's Avatar
You really don't need to change your oil every 2000 miles. In fact, it probably does more harm than good to change that often since motor oils don't operate at their full potential until a few hundred miles into its service life.
Im thinking about switching to german castrol next time too, but there doesn't seem to be much info about it on these forums.
Old Nov 6, 2006 | 06:28 PM
Fabulous71's Avatar
What dealership did you go to? All Mitsu dealers should be using Mobil 1 Synthetic for Evo oil changes. I'm guessing that Mitsubishi Japan tested the living crap out of the Evo using Mobil 1 and it evidently passed its tests for it to be recommended by Mitsu and literally printed on the oil filler cap. Mitsu has recommended Mobil 1 for the Evo since its launch here in 2003. Other high end synth oils are good also(Red Line, Royal Purple, NEO, etc).
I would also highly discourage anyone from trying dino oil in the car. There is one entire page in the owners manual devoted to letting the owner know NOT to use reg motor oil. It makes it clear that you could do damage to the turbocharger and other engine components. This high-strung engine does not need reg motor oil.
Old Nov 6, 2006 | 06:32 PM
evo9-power's Avatar
for winter i use 5w-30 cold weather
Old Nov 6, 2006 | 08:56 PM
evonick86's Avatar
Originally Posted by Evo9"Miss Rose"
"Search"!!!! i changed my first oil change at 2000 then ill be doing it at 5000....Personal Pref. 10w-30 Royal Purple
I had royal purple in my evo IX and i changed it today with mobil1 and it feels like the car pulled harder with the royal purple, that stuff is awesome!!! I have had my evo for about 2 months and im already over 6000 miles i need a beater car for commuting to work.
I was wondering if anyone had any opinions on using oil additives and octane boosters?
