Buschur Racing stage 5 kit with Dyno FLash mail in
Old Jun 21, 2006 | 12:52 PM
  #46
drewblueeye's Avatar
here is the link to the video of my 13.3
http://videos.streetfire.net/video/f...0a814bd163.htm
Old Jun 21, 2006 | 12:54 PM
  #47
Earthen's Avatar
Take it back to Buschur! That is all anyone should have told you. No one here can test drive your car and tell you if it is the car or your driving. So, again take it back to Buschur.
They will be able to tell you, because there is something very wrong with stage V Evo XIII and a 12.9@106.
Old Jun 21, 2006 | 12:55 PM
  #48
bluebyu36's Avatar
do a compression test maybe u just have one of slow evo's or a boost leak?i think you said u got tuned by al u should talk to him,did they tune you on the dyno or road tune?
Old Jun 21, 2006 | 12:57 PM
  #49
bluebyu36's Avatar
ya something wrong that launch looked pretty good it looks like the car falls on it face in third
Old Jun 21, 2006 | 01:00 PM
  #50
KOEvo's Avatar
It seems like you're driving alright. I mean there is some room for improvement, but that isn't the issue here.
What we are looking for now as other things have been ruled out is:
-Elevation, how high up are you
-Boost leak, do a pressure test, check out evomoto.com for the how to. This is the most likely cultpret. Your boost gauge will still show full boost even if you have a boost leak, CHECK IT.
-lastly, it could simply be the track, but this is very unlikely. If you are at anything lower then Colorado elevation, and have no boost leak, it is time to try another track and see what happens there. This event is very unlikely, but always a possibility.
Other then that it is a much better idea for you to get water/meth/alky injection first. You will get more power, and it is much safer.
Though i thought meth injection was part of the upgrade sequence? Am i wrong?
Old Jun 21, 2006 | 01:02 PM
  #51
InfraRed's Avatar
what was the 60 ft time on that run?
Old Jun 21, 2006 | 01:14 PM
  #52
my 60' on that run was also a 1.8,
I have done a compression test on the cylinders and i have done a pressure test up to 25 psi on the intercooler system and no leaks.
Old Jun 21, 2006 | 01:16 PM
  #53
MeKilla's Avatar
this is so strange.
Old Jun 21, 2006 | 01:17 PM
  #54
KOEvo's Avatar
There are no other options then except elevation and track. What elevation are you at? If less them 5000 ft then you need to go to a different track and see what happens.
Old Jun 21, 2006 | 01:18 PM
  #55
NO a meth upgrade is not included in the stage 5 kit,
My Altitude is 1,135 feet above sea level. and i use to take the car to Scribner, ne race track so i know it isnt the track and this track is amazing. it is a great track... great hook ups, i will give you guys all the info you need as long as i can figure out what is wrong
Old Jun 21, 2006 | 01:24 PM
  #56
SteveosEvo's Avatar
I think he is saying the timing might be off on the track.
Old Jun 21, 2006 | 01:29 PM
  #57
KOEvo's Avatar
Yes that is what i was implying, but no nobdy here can tell you what's wrong with your car. Sell it an start over, this is the weirdest thing i have ever heard.
Old Jun 21, 2006 | 01:33 PM
  #58
ok I have determined what i am going to do, FIRST OFF im not selling it and starting over. I am making a 12 hour road trip to BUSCHUR RACING to have them look at it. i think you guys are right, $5500.00 to drop 1.1 second???
Old Jun 21, 2006 | 01:35 PM
  #59
SilverNine's Avatar
back to the nitrous... nitrous is great and its not bad for your car if its properly tuned... an 80shot with proper amount of 110oct gas and a good tune should be perfect and quick.. only problem is that it gets adicting.. and you want more.... the power is amzing when you spray.
Old Jun 21, 2006 | 02:09 PM
  #60
LV///R's Avatar
Ah cool. Someone from the area! How often do you get out to TVR? I've been out there plenty of times to watch, and have heard that the track sucks, as in getting the cars to hook up. From what I've heard its "iffy" some weekends for the track condition. Basically what I'm trying to say, its probably not the best prepped track ever. What do you expect, we're in the middle of no where!
Did you run it on a test and tune weekend?
I'm going to shoot ya a PM. Gl with your situtation...
Maybe I'll run mine sometime soon, just to see what I can do stock...
