Problems with 04 evo
Old Jun 24, 2006 | 02:56 PM
evodrivesme's Avatar
I just purchased my evo a few days ago knowing there were a few problems but could all be solved with a tune anyways, Im having a problem starting the car it doesnt want to turn over and it sounds like the starter is just moving but the motor isnt turning over but then after 3 tries and giving it a little throttle it will turn over and start. I just got a check engine light for (crank angle position sensor a malfunction in line) i think it said malfuncation 95% sure. It is also getting a code for random/multiple cylinder misfire but this will just come on when im driving and i cant feel anything happen usualy you can feel a misfire. the mods i have on the car are hks 272 cams, walbro 255 fuel pump, vishnu xede, perrin 3in dp and exhaust and 3in high flow cat.
Old Jun 24, 2006 | 02:58 PM
Mulholland0132's Avatar
You bought the car with these problems???????
Old Jun 24, 2006 | 03:06 PM
no i bought it knowing it needed tuning. didnt know about these other problems till today.
Old Jun 24, 2006 | 05:52 PM
DrivenToThrill's Avatar
Hello
daaaang thats sucks. Try removing the starter and putting it back on. if that doesn't work, you'll need and trained Evo mechanic.....cause I don't think Mitsu will warranty it.
Dante`
Old Jun 24, 2006 | 06:08 PM
bigfishs's Avatar
If you bought it from a dealer, take it back. In most states you get at least one month warranty
Old Jun 24, 2006 | 06:27 PM
Yeah what he said. Thats sounds like good idea
Old Jun 24, 2006 | 07:21 PM
yes i dont know the conditions of the warrenty with the dealer i bought it from because of the aftermarket **** but i will look into it. its like obviously they had a Creader and they deleted this **** before i test drove and it and picked it up..
Anyways im still having a really hard time getting it started up and i am getting a code now P0335 (Crankshaft Position Sensor Circuit) i dont know if this meens there is a short in the line or the sensor has gone bad. im not really a mitsu guy im movin over from honda and dont even know where to start! Where on the block is this sensor located exactly?
Old Jun 24, 2006 | 07:38 PM
elhalisf's Avatar
you will need to remove the crank pulley, water pump pulley and the timing belt cover to see the crank sensor. its right where the crank is.
it might have gone bad, but usualy if they have, your car wont start up at all. see if your getting spark when u try to start it up.
Old Jun 24, 2006 | 08:29 PM
alloyic_rs's Avatar
how much did you buy it for?
Old Jun 24, 2006 | 08:32 PM
well hopefully it has something to do with my vinshu xede then because that sounds like a lot of work just to get to a god damn sensor lol. when i try and start it, it sounds like when u accidently try and turn a car on and its already on and then eventualy after trying it enough it will turn over. im taking to a local shop called hybrid dynamics near where i live in youngwood, pa hope fully their tech guy will be able to help me out with a street tune and before that he will be able to find out why the hell this other **** is happening.
Old Jun 24, 2006 | 10:27 PM
how do u recomend checking for spark? taking one of the wires out and puttin a screw driver in it and watching for spark?
Old Jun 25, 2006 | 07:12 AM
dookgvr4's Avatar
Don't be a moron and bring it back where you got it from.....
We cannot E-tune your car for you
Old Jun 25, 2006 | 07:47 AM
lol your retarded dude i didnt ask anyone to e-tune the ****ing car, i know it needs TUNED thats why i was taking it to get tuned on monday. This is a problem that has nothing to do with tuning thats why i was asking if anyone has had this problem before what i can look for where to look. Plus you just cant take a car back thats got some mods done to it and be like oh ya 3 days later its not running right, they dont know if you have been beating on it or what its a little more complicated it involves lawyers and such something you probably know nothing about.
Old Jun 25, 2006 | 10:16 AM
Should i be hearing the fuel pump click on and stay running with the car in the ON position. Also could a bad starter be causing these problems? Starter will crank but does not turn the car over every once and a while you can see the cams move a little bit but not much.
Old Jun 26, 2006 | 12:07 PM
sonicnofadz's Avatar
1.) Try replacing the battery or getting a jump start.
2.) Check for spark by unplugging one of the ignition wires (while it is dark out) and seeing if it draws an arc against a metal surface (or just use a tool that lights up when it detects current flowing through a wire)
3.) If your battery is good, and the engine is turning over, and you have spark, then you have a fuel problem. Test the injectors and fuel pump.
