installing authority exhaust shield??
Old Jun 30, 2006 | 02:36 PM
white venom's Avatar
Question installing authority exhaust shield??
I am in the process of installing an authoruty carbon fiber heat shield and was wondering if it is ok to just use double sided 3m tape?? or should I use the screws it came with also???
Old Jun 30, 2006 | 02:41 PM
ray3328's Avatar
You can screw the two bottom bolts on the underside of your bumper and use the tape to hold the front. It won't be as flush as if you put all the screws but it will work fine.
res04's Avatar
try tape first, if it does not fly use the bolts.
Old Jun 30, 2006 | 04:51 PM
pog0's Avatar
I used just double sided 3m tape... A LOT just to be safe. Mounts pretty flush except for one part and I dont wanna rip it off cause theres just way too much tape on it.
