where can i hook up A/F gauge?
Old Jul 6, 2006 | 12:18 AM
ApexVIII's Avatar
where can i hook up a narowband A/F gauge? i know that i can go to the ECU but i dont know what prong and where it is. or i can go to the oxy sensor but im not sure.
Old Jul 6, 2006 | 12:31 AM
sesso's Avatar
dude return it and get a wideband. narrowband wont tell u anything good
Old Jul 6, 2006 | 12:32 AM
housedj's Avatar
+1,000,000,000,000
Old Jul 6, 2006 | 05:56 AM
evolgrl's Avatar
I'm with them^.
Old Jul 6, 2006 | 05:57 AM
gsrboi80's Avatar
^me too
Old Jul 6, 2006 | 06:03 AM
LancerEVOVIIISD's Avatar
To answer your question, yes you can tap it into the O2 sensor.
With that out of the way, I agree with these guys, it doesnt do anything for you unless you just like to look at the pretty light flicker back and forth. Get a wideband.
Old Jul 6, 2006 | 06:30 AM
JaReDbOy's Avatar
There's a really good install thread I referenced this weekend when I hooked up mine:
https://www.evolutionm.net/forums/sh...r+fuel+install
I used a wiretap into the white wire.
Although I kind of have to agree with the above posters.. i pretty much have a gauge that has a pretty light bouncing back and forth lol.
O well I bought the gauge a few years ago and decided to still use it. Oil pressure might have been a better buy imo.
Old Jul 6, 2006 | 06:42 AM
ApexVIII's Avatar
ya i would have but i got the 3 gauge a piller and i got Oil PSI, Boost and i needed another one that was cheap. so i got that one. i wont use it for tunning or anything its just to fill up a hole
Old Jul 6, 2006 | 06:46 AM
MalibuJack's Avatar
You might be better off with an EGT gage or something.. the narrowband gages are basically useless.. At least on the Evo because its O2 sensor is just so slow to sample..
FWIW the flashing light you see is the closed loop fueling.. The big problem is you just can't tune with it, most are calibrated to show values at WOT, unfortunately I think there are only a few 10ths of a volt in that area which makes it not in any way fast or accurate enough to be useful...
You'd be much better off with a clock in that unused opening.. hehe.. Oil Temp might be a good alternative, since that is a good bit of data to monitor and its a fairly inexpensive gage.
Old Jul 6, 2006 | 07:01 AM
bigric09's Avatar
or water temp, throw that narrow band at some kid with a civic, its a waste of time for us and our cars... happy ditching
Old Jul 6, 2006 | 09:04 AM
JaReDbOy's Avatar
i have egt, boost and a/f.
but its too late!
lol i hooked it up already and im not gonna pull it off
maybe next time
Old Jul 6, 2006 | 10:15 AM
ApexVIII's Avatar
can i use a add a splice to the white wire?
surfnsp66
Evo X How Tos / Installations
May 5, 2013 04:04 PM
wags528
Oct 14, 2009 08:15 PM
edbighead
Jul 10, 2008 01:51 PM
ddubdb3
Dec 10, 2006 05:12 PM
rt turbo
Dec 11, 2004 11:19 AM
