Boost question? Could be a problem.
Old Jul 10, 2006 | 07:23 AM
gl4662's Avatar
Anyone ever start your car in the cold or heat and notice that the boost only maxes at like .7 bars? It's done that a couple times for me, but after a little while it will go back to the normal 1.5-1.7 bars. Is this a problem? Or does the car just need to warm up a bit?
thanks!
Old Jul 10, 2006 | 07:27 AM
AF-Evo8's Avatar
i always warm up my car when i go to work in the morning just to be safe, i don't think its good to be boosting on a cold engine.
Old Jul 10, 2006 | 07:28 AM
gl4662's Avatar
Yeah, right on. It's only happened a couple times, so I am wondering if I just forgot to let the car warm up on those days.
Old Jul 10, 2006 | 11:38 AM
Warrtalon's Avatar
Wow, you are trying to boost when the engine is cold? Do not do it ever again - do not hit boost until the engine is at full operating temperatures. That is a sure way to blow your engine. It's a good thing the ECU is programmed to suppress the boost so as to protect the engine, else you'd be at the dealership now making a warranty claim.
Old Jul 10, 2006 | 11:56 AM
travman's Avatar
Seriously how do you forget to let a car warm-up some days?? Its not a hard concept, its like brushing your teeth every morning, do you forget to do that too
Old Jul 10, 2006 | 01:12 PM
gl4662's Avatar
Rad, thanks guys!
Old Jul 10, 2006 | 01:16 PM
gsrboi80's Avatar
Running the **** out of a cold engine. Smart very smart
Old Jul 10, 2006 | 01:59 PM
gl4662's Avatar
Nah, it's only happened like two times to me. I've never beat my engine without giving it a couple minutes of slow driving to warm up. I was just curious why it had done that in the past. Thanks for the information guys!
Old Jul 10, 2006 | 02:02 PM
hondafan's Avatar
i always wait for the temp needle to move past the lower temp line before moving and wait for stable oil temps before beating.
Old Jul 10, 2006 | 02:05 PM
Warrtalon's Avatar
That's a bit too long at idle, hondafan. YOu should warm the car up by driving, no by idling. There's a technical write-up on why that is bad for your engine, but I have trouble finding it. Let the car idle a little until the needle starts to move, but don't wait idle for several minutes. Drive lightly until it warms up fully, then boost.
