tcase,rear diff has to be diaqueen only??
Old Jul 13, 2006 | 04:47 PM
deegaw11's Avatar
i have searched and read many many threads about this and im so confused!!
many ppl here have said to use diaqueen ONLY for the tcase and rear diff but also there are some ppl who uses 75w-90 and they even did write ups on how to do it.
my car has about 32,000 so i think i need to change them real soon so will it be ok if i go buy something like mobil 1 synthetic 75-90 or only diaqueen??
pls only answer me if you are for sure if its ok or not.
Old Jul 13, 2006 | 04:52 PM
Warrtalon's Avatar
Why bother changing? DiaQueen LSD oil is recommended.
mitsubishiparts.net
Old Jul 13, 2006 | 05:52 PM
MaxR's Avatar
u need a straight 90 weight GL5 hypoid gear oil for the tr5ansfer and rear diff.
Old Jul 13, 2006 | 05:54 PM
EvoDan2004's Avatar
gl4 you meen? i beleave this is what they recommend. mitsu parts.net is a great place.
Old Jul 13, 2006 | 06:06 PM
trinydex's Avatar
mitsubishiparts.net
because there are fluids that will protect your hardware better than the stock watery stuff. people just don't seem to do the research and you always have the background noise of 20 idiots that purchased what their local idiot told them to.
for the tcase redline shockproof is very good, it's gooey it coats everything nicely.
for the rear diff you need something that has the right friction modifier. roadraceengineering uses redling 75 90
http://www.roadraceengineering.com/eclfluids.htm
Old Jul 13, 2006 | 06:19 PM
MaxR's Avatar
naw man, gl4 for your transmission. and a gl5 for your transfer case and rear diff.
Old Jul 13, 2006 | 07:22 PM
mdosu's Avatar
ok...I just had a t-case replaced under warrenty, I have an 03. Now, I am super confused with what goes into the t-case for the 03!!
My mitsu tech told me to NOT to use Diaqueen in the t-case. He said Diaqueen in rear diff is okay.
He told me he used the shop's GX 80W-90 Gear Oil. I took a picture of the drum's label on my cell...and it also shows that it's made by Exxon.
He stressed that this gear oil has special Friction Modifiers that Diaqueen LSD Gear Oil does not have.
Can someone please confirm or disprove this?
The reason his message was reasonable to me was this: in the shop manual which he showed me, it never specified Diaqueen LSD for the t-case but did specify the Diaqueen for the real diff.
Old Jul 13, 2006 | 07:34 PM
trinydex's Avatar
here we go again
Old Jul 14, 2006 | 04:57 AM
barneyb's Avatar
For the rear differential the maker recommends GL-5 or higher SAE90, SAE85W-90 or SAE80W-90. For the transfer case the maker recommends GL-5 SAE90 only. So the transfer case has more stringent lubrication requirements than the rear differential does. I say this because making a multi-weight lubricant requires the inclusion of viscosity modifers and viscosity modifers are not oil and reduce lubricant properties.
So you can probably find on the shelf of your local auto supply store something that will work for the rear differential. However, finding GL-5 SAE90 gear oil is difficult. I think that there is only one other manufacturer besides Diagueen (you are welcome to prove me wrong here). Anyway, once you aquire Diaqueen for the transfer case you also have the correct lubricant for the rear differential. So, why not use it?
Old Jul 14, 2006 | 05:04 AM
SwabeLife's Avatar
only use OEM stuff when changing fluids. I used Dqueen on my diff and tranny.
Old Jul 14, 2006 | 06:00 AM
glgz's Avatar
I hope you meant diff and transfer case. I don't think you want to use Diaqueen in the transmission.
Old Jul 14, 2006 | 07:45 AM
gsrboi80's Avatar
Diaqueen in the TC and rear diff that dealer was smoking that stuff. Penzoil Syncromesh or somthing like it in the tranny
Old Jul 14, 2006 | 07:49 AM
bigric09's Avatar
i have redline lightweight in my tranny and the heavy in my tcase and adding it to my rear diff when i get my car back
Old Jul 14, 2006 | 08:47 AM
Jeff_Jeske's Avatar
EXACTLY!
ONLY USE DIAQUEEN IN THE XFER CASE!!!!!!!
You should also use Diaqueen in the rear dif.
I use Penzoil Synchromesh in the tranny and change it after every lapping day.
If you don't believe everyone telling you to ONLY USE DIAQUEEN in the xfer case call T.R.E. or Shep and ask them. They will specifically tell you NOT to use shockproof in an EVO xfer case.
Old Jul 14, 2006 | 11:22 AM
bigric09's Avatar
someone else had a shep rebuilt setup and written on it was diaqueen or redline only
