Hex size question
Old Jul 22, 2006 | 05:38 AM
2StepsAhead's Avatar
Hex size question
Going to install my oil pressure sending unit soon, heard the hex bolt down by the filter is a pain to get out. I don't think I have a hex key big enough so I might go run to sears and buy a hex key for a ratchet, anyone know the size of it by any chance?
Old Jul 22, 2006 | 06:23 AM
oguratevo's Avatar
Try 10mm or 12mm hex bit.
Old Jul 27, 2006 | 07:30 AM
It was an 8mm, found out the hard way...oh well they took the hex key back cause I didn't use it.
Old Jul 27, 2006 | 12:52 PM
f-dub's Avatar
It is 8mm. Make sure you get a 3/4 drive socket. You will need as much leverage as you can possibly get in order to remove that plug. I just finished removing mine about 5 minutes ago WD40 might also be required. Make sure you also have some thread sealant/teflon tape.
Old Jul 27, 2006 | 05:24 PM
I bought the sockets but it was tough to get at with a ratchet, the extension made it hit the control arm etc...so I used a regular L shaped allen key and put a pipe on it.
