Need help shifter bushing install.
Old Jul 22, 2006 | 01:11 PM
StreetRicer2010's Avatar
I am trying to install the interior shifter bushings for the bottom of the shifter plate. I have gotten all of the bolt off and now I am to the stock rubber ones. How do I get those out, no matter how hard I pull they just dont seem to wanna come out. Is there an easy way to get them out without having to remove the plate from the car. Sorry such a newb question..
Old Jul 22, 2006 | 01:46 PM
BuLocal's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=137164
Old Jul 22, 2006 | 01:49 PM
Thegame's Avatar
That's exactly the site I used to do mine. Good mod for the money. Hopefully you got the underhood bushings as well.
Old Jul 22, 2006 | 02:10 PM
Apex Racer's Avatar
It has been awhile since I changed mine out, but if I remember corectly I had to grab the the bushing with a needle nose and pinch it down real hard and then kinda spun the pliers in my hand like a screw driver. That basicaly "screwed" the bushing out. hope that helps
Old Jul 22, 2006 | 02:11 PM
RRRS's Avatar
make sure to remove the metal piece in the center, try pushing the rubber down while lifting the shifter cage slightly, use a screwdriver to shove it through.
i just did this mod hours ago, hardest part for me was inserting the Kartboy bushings, which is bigger than the hole, had a heck of a time getting them all in.
also done WORKS shifter and Kartboy underhood bushings. great mods
Old Jul 22, 2006 | 02:13 PM
Apex Racer's Avatar
I used a perrin adj short throw, but I would definetly have to agree with the Kart boy underhoods, I really felt the dif.
