Getting more than 300whp?
Old Jul 27, 2006 | 10:17 AM
kip's Avatar
kip
My IX is totally stock now and I'm going to have these mods installed next week. The shop said it'll put down roughly 300whp on a mustang dyno. I specifically asked for decently-reliable setup on octane 91 and stay street-legal.
Walbro 255 lph Fuel Pump
Sun Automotive Exhaust System - Evo Garage HRS Exhaust
Hallman Boost controller PRo RX KIT
Helix EVO 8 hight-flow cat 200 cell
HKS super hybrid panel filters
Tanabe Downpippe 2.75" (don't want to deal with the vibration issue of 3").
flash/dyno-tuning
What do you guys think?
Is there any other mod that I can do to bring the number up and still stay street-legal on 91?
How would I do compare to the M3 and older M5?
Old Jul 27, 2006 | 10:27 AM
vboy425's Avatar
you will be there no problem. on the note about 2.75" DP, it's good up to 600hp and it's the only one tht clear the IX nicely. the 3" is pretty close to the ACD. if you want to squeeze out even more WHP get some 660CC injectors. where are you located in California ?? there is a well know shop called Tuning Tech, give them a call and ask for Alfred, also tell them Charlie with the yellow evo sent you. http://tuningtechnologies.com/
About staying street legal, well you live in California so anything you do to your car is illegal and your mods list already way pass the legal side
Old Jul 27, 2006 | 10:40 AM
mac_05evo's Avatar
I don't have a IX and I could very well be wrong, but I've saw several IXs running a 3" TBE without any fitment problems. My VIII is also equipped with ACD and I have a 3.5" TBE and it fits without hitting anything. Like I said I'm not 100% sure but I think you'd be fine running a 3" TBE...
Anyhow, you shouldn't have any problems putting down over 300 whp. I've saw IXs with just a reflash on a low reading DynoDynamics put down ~ 270 whp.
Old Jul 27, 2006 | 10:46 AM
speedracer2169's Avatar
flash/dyno-tuning
Well califronia law does makes it illegal to replace a functioning cat on new cars with less than 50k miles so if you get nailed and have to see a ref you have to put the stocker back in, and the exhaust needs to be 95db comliant.
Old Jul 27, 2006 | 11:17 AM
emagdnim8's Avatar
California sucks lol
Old Jul 27, 2006 | 11:19 AM
kip's Avatar
kip
If I would forget about the actual street-legal part and still want to keep it "look/sound" street legal, is there any other mod for a good HP gain? am I looking at a bigger turbo?
Old Jul 27, 2006 | 11:40 AM
Warrtalon's Avatar
Actually, you shouldn't be so worried about the number "300," because this is apparently on a low-reading Mustang Dyno. That would be equivalent to about 330whp on a Dynojet, if not more. Unfortunately, there was no reason to get the 2.75" DP just to avoid a 3". There are many IXs with 3" exhausts and no rattling. Also, the HKS panel filter was not a good choice, since it can't be used for the life of the car. Otherwise, having a nice Hallman with a TBE and custom flash is definitely the right path for a IX. To get a little more reliable power without going crazy, you can add a stainless steel o2 housing, LICP, and port your stock manifold.
Then, wait to see if the GSC 280 cams for the IX make good power, because they are only $599 shipped, which is great.
Old Jul 27, 2006 | 02:08 PM
GVR4799's Avatar
I'd be pissed if I lived there.
Old Jul 27, 2006 | 02:17 PM
derangedazn's Avatar
You drive an evo and live in CA....cops will tail you anyways. Anything you do is illegal. "Sir your windshield washer fluid is a different color than mine.....here is a $200 ticket."
Old Jul 27, 2006 | 02:20 PM
-=SPECTRE=-'s Avatar
They will pull you over for your EVO because you failed to yield for the 500 illegal aliens rushing across the highway.
Old Jul 27, 2006 | 06:12 PM
hk2ronin's Avatar
actually replacing a functional cat with less than 50k miles that is not damaged is a federal law with heavy fines. Just take your stock cat cover off stock cat and put over test-pipe or high flow cat. If they do a visual underneath car it will look like a stock mitsu cat. My buddy does this with his test pipe and if you look under his car it looks like you are looking @ a stock evo. How many people have high flow cats or test pipes and actually get bagged for it? Not many @ least not on here.
