SEIZED alluminum underhood bushing!
Old Jul 28, 2006 | 07:56 AM
2StepsAhead's Avatar
So the aluminum ones don't get "stuff" on them or oxidize or seize or anything? Just the brass?
Old Jul 28, 2006 | 08:48 AM
nrcooled's Avatar
Originally Posted by Dr.Sound
yeah dude!
do i know you?
No we don't know each other but I do remember your spicy speed from the boards. I used to have a black speed but it got totaled so I stopped hanging out there.
Old Jul 28, 2006 | 09:18 AM
Dr.Sound's Avatar
mine didnt oxydize or get stuff on them. i just think thal lack of lubrication and dust did the trick.
at first i was SURE something got into the cable line that goes from the shifter through the firewall......i was ready to tear the dashboard appart.
i was actually relieved that it was only the bushing.
Old Aug 1, 2006 | 12:48 PM
Hamsterman's Avatar
Hey guys - I work for speed-source so i figured I would chime in here
This is a strange occurance, but we can get it fixed. Are the shifter cable bushings seizing up on the inside of the bushing on the pin, or on the outside of the bushing in the shifter linkage?
It looks like mitsubishi has changed up the shifter cables a tiny bit from year to year on the evo - and while they have worked fine on the cars we have installed them on - we need feedback like this to change design...
On the cars I have installed the bushings on - I have never even used lube and been fine - I wonder if there is water getting into the engine bay from the hood vent you guys have... Do most of you keep that stock water drain in the hood vent - or take that out?
We have been selling these bushings for years, and never really had any major reported issues from any group surrounding them liek this. We value your input a great deal - always feel free to message be if you have an issue with our products because we believe in producing the best quality fit and constructed items at the best prices. It was mesages like this that helped us find the cable differences in the 5 and 6 speed evos!
And just so you guys know - the shifter cable bushings are brass - the base bushings are alodine coated aluminum... The 360 navel brass we use is known for its self-lubricating properties and resistence to corrosion
19.5psi you have PM also
Old Aug 1, 2006 | 12:54 PM
Hamsterman's Avatar
Originally Posted by alloyic_rs
i hear more and more bad things about the speed source ones, not just this thread but other threads as well
If you could point me in the direction of any of those threads - I would appreciate it - since we would be happy to fix any issues surrounding the items we sell to the evo community.
I will search around the boards also - and see what I can find
Old Aug 1, 2006 | 02:39 PM
Dr.Sound's Avatar
my water drain is still there.
but, i do rinse my motor ocasionally, i believe this along with heat might have caused them to seize.
bushing itself seized at the pin, BUT i remember when i was putting the bushig into the linkage i had to force both of them in. we did 2 cars that day and bushings had to be forced on both.
they did however fit fine arround the pin.....not loose, but very percise.
Old Aug 1, 2006 | 04:16 PM
alloyic_rs's Avatar
https://www.evolutionm.net/forums/sh...rhood+bushings
here's another thread i was talkin about
Old Aug 1, 2006 | 04:45 PM
Dr.Sound's Avatar
^ dang, i though i was the only one.
Old Aug 2, 2006 | 09:47 AM
Hamsterman's Avatar
Thanks for the heads up - looks like a similar problem... That is so strange because with all of the time we have spent producing and selling these bushings - a problem has never really come up.
We will take a look at the bushings - the design, and position in the engine bay and see what kind of a solution we can have for your guys - beside just lubricating them often, because on the installs I have done, lubrication has not been an issue
Old Aug 2, 2006 | 10:29 AM
Zeus's Avatar
Used Speedsource when they first came out for the US Evo...used anti-seize and have not looked back... I'd suggest that over grease.
Old Aug 2, 2006 | 10:46 AM
justchil's Avatar
^^ ditto.. but after hearing this I will keep an eye on them
Old Aug 2, 2006 | 11:33 AM
dan628's Avatar
I have the speed source bushings and they work fine. It comes with sand paper for a reason so use it before you install them, thanks.
Old Aug 2, 2006 | 04:15 PM
Dr.Sound's Avatar
^ you're welcome
anyway, like i said before, they fit fine when i installed them almost a year ago.
Old Aug 2, 2006 | 09:22 PM
savageevo's Avatar
looks like everytime I change my oil I may need to check and relube that too More work to do in this damn heat we have.
Old Sep 18, 2007 | 08:20 AM
mifesto's Avatar
it depends heavily also on what type of lub you used before. lithium grease and sort may not stand up to engine temp for our car over a long period. in the other hand hightemp antiseize can stand up to exhaust temps so engine bay temp is a breeze.
