STOCK Evo 9 --> MR <-- Owners... Read!
Old Aug 2, 2006 | 09:27 PM
  #31
mr96gsx408's Avatar
Originally Posted by Max-Q
Dude, don't get your panties in a bunch. I think his point was that he wanted to know what the MR boost gauge reads and has no real interest in what your Defi gauge reads.
well if my defi gauge is highly more accurate, and gets similar readings, i'd assume it'd help clarify the issue at hand.
Old Aug 2, 2006 | 09:29 PM
  #32
hondafan's Avatar
if i'm not mistaken the factory guage reads in kg/cm^2, not BAR. it's a minimal difference but a difference non the less.
Old Aug 2, 2006 | 09:32 PM
  #33
High_PSI's Avatar
Please read my post above, I picked up 4 PSI with a 10MM wrench and it did NOT involve a MBC.
Old Aug 2, 2006 | 09:35 PM
  #34
hondafan's Avatar
+1. the first time i did a boost leak test i was like HOLY S%$T! at least 3 leaks including a torn vacuum line.
Old Aug 2, 2006 | 10:15 PM
  #35
IX-Is-Mine's Avatar
Originally Posted by mr96gsx408
uh.. yes, evo 9 RS's come with the same gauges as MRs do, at least my buddy's and the cool 5spd aluminum shift knob. I don't really want to get into a pissing match to see who knows what, but if the thread owner knew anything about evos, he would of included RS's as well.
/unsubscribed
Thanks for the input, I had no idea RS's come with the same gauges, I dont get why GSR's dont
Old Aug 3, 2006 | 07:38 AM
  #36
Kee1pride's Avatar
Kevin, 1.5 bar is 21.75psi. Stock boost is 20.3psi, which is 1.4bar.
time to get an aftermarket boost gauge put in then lol. i guess mine's faulty because it almost reaches 1.5
Old Aug 3, 2006 | 12:14 PM
  #37
thisonecountz's Avatar
Trust me that 6th gear... makes a diffrence
Do MR owners even read their specs sheet before they buy the car? I mean even though you have the same engine and the same turbo as any other evo 9, you want to only compare MR s? That's retarded...
haha .. i have a gsr, and my defi's see the same drop.
My buddy's evo 9 RS with the factory gauges see the same drop too...
same engine load + same turbo= same amount of boost rise/fall
gearing affects it minutely, and i dont think it matters very much in your instance except for the extra money you paid...
Old Aug 4, 2006 | 12:26 AM
  #38
DruMMinStUd06's Avatar
i only hit 1.1 kg/cm^2 on my stock IX MR.
Old Aug 4, 2006 | 01:53 PM
  #39
tirbolag9's Avatar
when i got my ix MR back in march, boost would spike to 1.4-1.5 bar. about two months ago, my ix is boosting to 1.2-1.3 bar. i just changed the clamps to t-bolts and still gettin 1.3 bars. bosst never drops below 1.1 bar.
i have 5470 miles and the only mod i have done is a works drop in filter. so far, no cel's.
Old Aug 4, 2006 | 01:55 PM
  #40
alby988's Avatar
same
Old Aug 4, 2006 | 03:19 PM
  #41
DreamLike1's Avatar
/unsubscribed
Umm... I'm sorry I was not aware that evo 9 RS's come with the same gauges. In fact I would like to hear from other RS owners if this is true, because I've never heard of them coming with a "cool 5spd aluminum shift knob" either...
And just like Max-Q said, I included only factory boost gauges because that is what I have. Its common knowledge that some boost gauges read differently than others, and there is much room for error. Your gauge reads in PSI, mine in BAR (or kg/cm^2 whatever it is). I'm not trying to glorify MR's or anything like that, just trying to get accurate information.
Is that peak boost? If thats the maximum boost you see on your stock IX then something might be up. I'm only hitting 1.2-1.3 but 1.1 is really low.
pm'd
Old Aug 4, 2006 | 03:25 PM
  #42
FJF's Avatar
FJF
Both are included in the optional RS Package.
Old Aug 4, 2006 | 03:29 PM
  #43
DreamLike1's Avatar
guess ya learn something new every day Was this true for '05 as well?
Old Jan 5, 2007 | 09:03 AM
  #44
LoRo's Avatar
I'm peaking at 1.4 bar (20 - 21PSI) then tapering down to 1.1 to 1.3BAR (17 - 19 PSI) I have hit 1.5Bar once on a cold morning (21.75 - 22.14PSI depending on your math) So I think it is totally normal.
Old Jan 5, 2007 | 09:18 AM
  #45
hamflex's Avatar
Yeah that sounds perfectly normal, especially on a clod night/day. I have an 05 MR...all the mods in my sig. And i just installed a greddy electronic boost guage, and i still have the factory one hooked up. The factory guage is no where near as reasponsive to boost as the greddy unit. But when i installed the greddy i did a 2nd gear pull and hit 25psi and held right around 18 to 19 psi. And thats with no tune, and no boost controller. Needless to say on pump gas that NO GOOD!
