Titanium turbo ??'s
Titanium turbo ??'s
Seems everywhere else in the world gets the Titanium wheel turbo and we get a non titanium turbo
Does anyone know how much power and or spool up - if any - we are loosing from not having a titanium wheel in out turbo ?? Thanks
Actually, while there might not be any noticeable difference in spool up time, there would have to be some difference. Because of the physics involved, if the turbowheel has less mass and the same general shape the moment of inertia will be less. That means it will take less energy to make it spin, hence faster spooling. Of course, I don't know the exact physics for a turbowheel, so I can't help much there.
The equation would be generally like this though: C*M*R^2 where C is some constant related to the shape of the wheel, M is the mass, and R is the radius of the wheel as a whole.
*Disclaimer: Highschool physics. Could be wrong, take it for what it's worth
The titanium part of the turbo is just the casing isnt it?
The actual wheel may be the same
titanium just dissipates heat better than the iron turbo we have
plus it probably weighs a hell of a lot less
the iron turbo probably costs less too
Originally posted by SilverEvo8owner
They probably changed to cast iron to keep the under 30 grand
http://www.micronmetals.com/titanium.htm
http://www.micronmetals.com/iron.htm
But the current turbo on the Evolution VIII isn't exactly plain iron. The turbine wheel is made of Inconel. About 40-50% cheaper than titanium.
http://www.micronmetals.com/inconel.htm
Inconel is easier to work with than titanium too making it much more cheaper to make Inconel turbine wheels than titanium turbine wheels. Inconel isn't exactly crap either so Mitsubishi isn't ripping you of either if thats your current impression from my writting. Inconel is actually used in Formula One racing too. Here's a good article about Inconel and it's uses.
http://www.burnsstainless.com/TechAr...l_article.html
Edit: Check out the site Evolution encyclopedia too. Gives some good info about the Evo VIII turbo too.
The titanium wheel turbo spools up quicker than the regular turbo as it is lighter. This leads to less turbo lag.
Titanium turbo is an Option on the non-US Evos and it isnt standard. If you already have the standard turbo, it isnt worth the trouble/cost to get the titanium turbo as the cost outweighs the benefits(which isnt that much).
