O2 sensor in cat stripped threads! HELP!
Old Aug 11, 2006 | 05:07 PM
mystang97's Avatar
Question O2 sensor in cat stripped threads! HELP!
So I changed the exhaust to the AMS tbe and while taking out the sensor from the cat the threads stripped out. I called mitsu and they said its 400bucks for a new one!! The sensor itself is fine but wont stay in the pipe. Any ideas on what to do??
Could i put a small tig weld on it to hold it in the AMS pipe??
Can I get an aftermarket sensor for it other then OEM??
Old Aug 12, 2006 | 02:23 PM
mystang97's Avatar
Anyone???
Old Aug 12, 2006 | 02:38 PM
rice_rocket88's Avatar
So it's the pipe that's stripped or the O2 sensor? Either way you can weld a new bung in and you're ready to go. Either that, or go buy those "antifoulers" and still you need to weld it in.
Old Aug 12, 2006 | 03:19 PM
revvin9k's Avatar
I believe the threads on the O2 sensor are stripped. Either way, you either spend $400 on a new sensor, or you tack weld the one you have in place for now. I would do the anti fouler or mechanical O2 fix now that you're in there.
Derek, let me know if you need anything.
Old Aug 12, 2006 | 10:17 PM
jkim1201's Avatar
You can get generic o2 sensor from auto store for less than $100, I believe brand was Bosch that my local store carried for $94.99.
Old Aug 13, 2006 | 08:11 AM
emagdnim8's Avatar
I'd get a spark plug antifouler and weld the o2sensor to that
Old Aug 13, 2006 | 08:26 AM
bigfishs's Avatar
Phone oxygensensors.com or sumitracing, they shold be able to hook you up with a non oem one for around 100 bucks. If you need a oem one you can get it from mitsubishiparts .com
Old Aug 13, 2006 | 08:43 AM
Genesis8's Avatar
+1
jkim1201]You can get generic o2 sensor from auto store for less than $100, I believe brand was Bosch that my local store carried for $94.99.[/QUOTE]
Old Aug 13, 2006 | 09:52 AM
Jussb1aze's Avatar
go get a craftsman tap & die set for like 50 bucks and fix both problems
Old Aug 14, 2006 | 10:39 AM
mystang97's Avatar
THanks for the info. Adam over at devo tuning is going to try and rethread it for me first. If that doesnt work ill have to try oxegonsensors.com
