smelly a/c ?
Old Aug 16, 2006 | 09:37 PM
PA-silver03evo's Avatar
We use it at the dealership I work at and it seems to work good. You just set the controls to run the fan using outside air and spray it in the cowling area where it sucks in air. If you get a can, it lasts a while so you can use it and if the smell comes back, use it again.
Originally Posted by confusionisbad
Has anyone tried this stuff mentioned above with success?
Old Aug 16, 2006 | 11:24 PM
daisaw1219's Avatar
You can do two things....
1. before you turn off your car run the fan only with no A/C for like a minute or two then you can leave.....Its great if you have a turbo timer becasue you can leave it and forget it.
2. find the inlet hole to your ac system....Its usually right below the windshiled on the outside in the middle. Spray some lysol there and run your Heat on High for like 5 mins and then the smell goes away it also freshens the system by killing the mildew and making the car smell fresh.
Old Aug 16, 2006 | 11:28 PM
gregfromblur's Avatar
lysol,, followed by some fabreeze.
Old Aug 16, 2006 | 11:35 PM
ModenaTwinTurbo's Avatar
cool cool cool i like the lyson tip the most, good info. fridgy fresh is for ballers tho hahaha.
Eddie Rosado
Old Aug 17, 2006 | 06:21 AM
Bigl4201's Avatar
hey , thanks a lot guys for the responses ! it makes sense to me that it would happen if i dont let the fan run after turning off the A/C, thanks again
Old Aug 17, 2006 | 02:08 PM
evobeatsti's Avatar
yah i have noticed that in my car also, but my moms mercedes does the same thing so does my dads bmw so i think its normal usually the smell goes away after a minute or two
Old Aug 18, 2006 | 11:36 AM
MyGlue's Avatar
I use anti-bacterial lysol. Works good for me.
Old Aug 23, 2006 | 05:25 AM
SHhhhh's Avatar
If you keep your AC on RECIRCULATE all the time, then you will get a smell from the vents. You can get rid of the smell by switching the AC to INCOMING AIR. I used to have a Honda Prelude and the owners manual said to do this a few minutes before shutting off the car. Because of this smell, I always use INCOMING AIR on my truck. Hope this helps!
Oh yea, Frigi-Fresh works wonders too!
Old Aug 23, 2006 | 11:28 AM
M1chael322's Avatar
you get that smell alot when you use A/C. what i do to get rid of it, and not have it come back is at the end of the day when i park my car into the garage i turn up the fan full blast for around 1 minute (no ac, and use outside air) so then all the bad smell can get out of the vents in the end of the day. If you don't get the bad smell out in the end of the day it will stay there overnite and get worse. Like a Rotting egg ^^
Old Aug 23, 2006 | 11:33 AM
Mekanic's Avatar
the mitsu dealer near me does basicly an A/C check and tune like for your house for like $60.
Check and top of freon, clean the ducts, clean the evap coil, and change the cain filter. Pretty sweet deal imho
Old Aug 14, 2007 | 06:34 PM
JohnnyBoy427's Avatar
what if I only get this bad smell when there is NO A/C on?
Old Aug 14, 2007 | 09:06 PM
UCLAevoIX's Avatar
Originally Posted by ~EVILEVO~
the problem is that if you just shut your car off with the AC on you can get condensation in the lines and such, a good way to prevent the smell is to shut the AC before shutting of the car.
i.e. turn the fan on full blast till the air goes warm, before turning of the car
good luck.
now that sounds like a good tip. i've heard of pinesol in the vents, but that did nothing in my 15 y/o accord.
all a/c systems have this problem - it's not a mitsu thing. stop the mitsu bashing already. if it were really that bad, you wouldn't be driving what you drive.
Old Aug 15, 2007 | 05:59 AM
Chemwarrior's Avatar
I've just started noticing this problem as well since I have been running my AC more due to the hot weather. I thought it might be the in-cabin air filter. It smells like mold/mildew. I guess I'll go buy some air freshener of some sort and clean out my filter.
Old Aug 15, 2007 | 10:39 AM
fuzzyduck808's Avatar
good luck.
cool, i learn something new everyday! Thx!
Old Aug 15, 2007 | 12:13 PM
Greg Haymann's Avatar
Check that cabin filter and replace every 15K.It works for me...
