2" Racing Harness for autox
Old Aug 20, 2006 | 10:51 PM
Dream Came True's Avatar
Hi.
I was looking around for a racing harness to hold my body when I got autoxing.
I've realized that there are quite a price difference between 3" and 2" racing harness. 3" is pretty expensive but DOT certified or something.
Is 2" harness just for a show? does anyone autox with 2" harness?
I'm gonna only use a harness for autox and not on the street.
It's a safety device so I shouldn't go cheap but just wondering
Old Aug 21, 2006 | 03:53 AM
nnorris7413's Avatar
I have a pair of Sparco 2" 3 point harnesses that i was gonna use for autocrossing but i dont need any more because i just crashed my car. If youre interested im selling them for $100 a piece.
Old Aug 21, 2006 | 04:06 AM
evojacko's Avatar
i have some schroth harnesses. they bolt into the rear seatbelt anchors. i think they cost about 140 each.
Old Aug 21, 2006 | 08:57 AM
EVOlutionary's Avatar
Alot of autocross racers use relatively cheap 2" harnesses. They are just to hold you in your seat rather than a true safety device like an FIA or SFI approved 5, 6 or 7 point harness. As you mentioned, don't use them on the streets. I think there is only one 4-pt harness that is DOT approved for use on the street - a special Schroth harness that has a special feature built in to help keep you from crushing your noggin if you roll your car.
EVOlutionary
Old Aug 21, 2006 | 07:14 PM
EVOlutionary
I was thinking about how DOT can approve any racing harness for the street use. Evo seems to have a seat belt pretensioner on the retractor so if you use a racing harness, you won't be pushed toward the seat at all.
However, I think if it's install good, 4 pt harness should work as good as 5, 6, or 7 pt harness at autox speed.
Old Aug 21, 2006 | 07:23 PM
DocWyte's Avatar
The Schroth belts (Rallye3,4 and AutoControl) are DOT approved. They have a stiched in section that breaks loose when you get into a crash. That way you don't get mushed.
They're good for auto-x and DE's, but if you're really hauling ***, a rollbar and a 5-6 point Schroth Profi 2 is the way to go. They have a 3" shoulder belt and 2" lap belt...
Old Sep 17, 2006 | 09:54 PM
EVOlutionary
I just measured the stock seat belt and it is slightly smaller than 2". I guess after market 2" harness should be equally safe with helmet on. I don't think seat belt pretentioner won't do the job when air bag deploys if the driver's wearing a racing harness. The pretentioner only retracts enough to pull the driver against the seat so if the racing harness is worn propery, it should be as safe as stock ones.
This is what I think.
Old Sep 17, 2006 | 11:35 PM
SophieSleeps's Avatar
Just cause it's 2" does not mean it's not DOT approved.
As others have said, scroth is popular. I have some in my car.
You have to be careful though. A lot of people mount them to the rear seat bottom anchors, but you really shouldn't do that. It's dangerous in the event of an accident. I guess it's ok for autocross if you're just trying to keep yourself in your seat.
The shoulder mounts should be as horizontal as possble...either going to a harness bar or to the rear deck seatbelt anchor locations.
Old Sep 18, 2006 | 07:05 AM
DocWyte's Avatar
True, but Schroth is DOT legal. On most harnesses you want to keep the tail straps at less than a 15 degree downward angle. However, the Schroths are approved to use the lower seat belt mounting points, must be because of the ASM technology. They wouldn't say it's ok to mount them there if it wasn't...
Old Sep 18, 2006 | 07:32 AM
The scroth belts I have say specifically NOT to mount them there.
I got them a few years ago...so maybe they changed some technology.
