brand new evo9 mr has pully noise already!
Originally Posted by yesevo
i have damn metal grinding noise i think its from pully......is it somewhat normal...or defect ...? anyone got same problem????????
The Timing Belt will make a noise, similar to a bad pulley (bearing), when cold. I was told by the dealer, it's a harmonic noise at a certain RPM. Dose it make the noise around 1200 RPM, maybe a couple of minutes after starting the car? If so, it's not a problem, it's the belt and disappears after the belt warms up.
If it's coming for your Power Steering, manufacturing sometimes cranks down on the seal to much and can create a winning noise.
What he is saying is that he's not giving the Evo enough time to warm up before driving. Let the car sit and idle until your temp goes up and the idle dropps to about 1k. If you don't do this and drive it cold, the Evo makes all sorts of weird noises when cold.
is it a whining sound coming from the turbo? If it is then it is music to my ears. The evo is one loud engine and I have no complaints.
