need help
Old Aug 25, 2006 | 05:29 AM
team_ghost's Avatar
need help
I was driving yesterday in 3rd at low rpms and my car just died out on me and now it won't start. Its not the battery everything in the car turns on. The motor is turning over just not going on. I don't kno what's wrong with it. we're gonna try and find out what's wrong with it today but does anybody have any suggestions. Thanks
Old Aug 25, 2006 | 05:37 AM
MuslimEvoFreak's Avatar
Alternator or starter maybe?
Old Aug 25, 2006 | 05:39 AM
cubantexan's Avatar
sounds like your intake manifold pipe/slicone hose blew off. Just make sure all pipe are on tight. this is a common occurance.
Old Aug 25, 2006 | 05:40 AM
oooooo nice ^^^^^^^, learned something new today!
Old Aug 25, 2006 | 05:42 AM
EiEVO's Avatar
WTF? Are you kidding me... He said it turns over... The motor cranks...So that would me the battery has power. It doesnt matter if the alternator is bad or not.. it it cranks then it should fire.
As for what to check.. you need to give more input. Did it make a noise... were you under boost. we cant just guess for you, come'on help us determine your problem.
Old Aug 25, 2006 | 05:44 AM
I am new to this stuff. Give me a break man. I am in Auto Tech class and it started last Monday. I still have a lot to learn.
Old Aug 25, 2006 | 07:41 AM
team_ghost's Avatar
No noise wasn't in boost yet motor just stalled its getting power I'm thinking it might be a fuel preoblem or a head problem we tried to check the timing yesterday and it seemed off
Old Aug 25, 2006 | 08:38 AM
chronozon's Avatar
If all checks out fine, could it be the chip inside the key? A friend of mine had similar problems with his car (not an evo) before, couldn't start even though all lights comes on and the engine turns, problem was the chip in his car keys got fried.
Old Aug 25, 2006 | 05:39 PM
team_ghost's Avatar
Ok we checked the car out we found that the engine fuse keeps blowing.we changed the fuse and the car started back up.took it for a drilve and it died again. can somebody tell me why this or get the diagram for all the connections of this fuse. We were thinking that it is a bad ground somewhere. We
Also noticed that the car weas running real rich smelled badd. I just need some help I was going to take it to turbo trix tomorrow nut I thibk everyone will be at the track
Old Aug 25, 2006 | 11:05 PM
timzcat's Avatar
If you searched you would probably have found the answer.
Do you have an aftermarket catback? How about anti-foulers on the O2 because of a cat delete pipe?
Check the rear O2 sensor wiring for shorting to ground against the heatshield.
Old Aug 25, 2006 | 11:10 PM
speedracer2169's Avatar
how about checking you fuses? maybe the fuse for your fuel pump went out
Old Aug 25, 2006 | 11:19 PM
timzcat's Avatar
Old Aug 26, 2006 | 06:07 AM
team_ghost's Avatar
Yes I have an aftermarket tbe with cat delete I'm going to check the sensor when it stops raining but would that pop the enging fuse and I did search couldn't find anything also had one of my boys who is an electrical engineer trying to find the diagram for the wiring but we couldnmt find it
Old Aug 26, 2006 | 12:47 PM
timzcat's Avatar
It has happened to a few people. That fuse powers the sensors for engine control.
Old Aug 27, 2006 | 01:09 PM
team_ghost's Avatar
Aight I fixed it. It was my rear o2 sensor it kept hit against my underbody which frayed the wires causing a short so thanks for the advice saved me a couple huindrd of dollars.
JDMEvoVII
Oct 20, 2016 10:03 PM
asoom90
Jan 7, 2013 01:49 PM
Nvr2old32
Sep 29, 2008 07:51 PM
Evo_Jr
Lancer Troubleshooting
14
Feb 4, 2007 11:06 AM
