Factory Boost Gauge Tie-In Point
Old Aug 25, 2006 | 09:49 AM
11SECEVO's Avatar
Guys,
Installing my Autometer B gauge tommorrow, and I really Dislike Hacking into the FPR hose as suggested in ALL the Install Threads here, so where do they Tie-In the facotry gauge on the MR & RS (I have a IX)....a Search brings up ZILCH
Thanks!!
Old Aug 25, 2006 | 09:59 AM
TURBODAWG's Avatar
On my 05 MR it was tapped into the FPR line. On my friends 06 MR it was tapped into the BOV vac port where it comes off the intake manifold. (Follow the lines from the stock BOV back to where the vac line gets to a pressure port on the intake manifold). The stock tie in was in the line right of the intake manifold, on his 06 model MR.
Hope that helps
Brian
Old Aug 25, 2006 | 10:07 AM
idriveanevo's Avatar
my factory t broke but this is where it is
Old Aug 25, 2006 | 10:08 AM
11SECEVO's Avatar
Brian,
Thanks, yea I was Thinking the BOV port, sounds like a Great Location
Old Sep 30, 2006 | 04:56 PM
zeRo IX's Avatar
ok i taped into that line... and i am still having a problem. still get a -20 vac (idle, driving).
the most it boost at is like +20 if that. but does NOT zero out when idle or drive while not boost.
Old Sep 30, 2006 | 05:00 PM
kreionic's Avatar
When you idle you should be around -20 to -15. The only time it should zero out is when the car is turned off
Old Sep 30, 2006 | 05:06 PM
ak47po's Avatar
Go here for install instruction's
http://evomoto.com/tech_info.php?tPa...8749bf49d175d4
Old Sep 30, 2006 | 05:16 PM
zeRo IX's Avatar
so seeing it at -20 when start up and move up to zeronce i give it gas and more gas it goes up more and more.... that is all normal? i dont have a broken gauge?
Old Sep 30, 2006 | 05:17 PM
zeRo IX's Avatar
Originally Posted by ak47po
yeah i did all that. but now i rana line to the BOV vac line to the man. so now i guess im SOL on switching i back tonight. :|
Old Sep 30, 2006 | 05:21 PM
kreionic's Avatar
Yes your gauge is working and those numbers are normal.
Old Sep 30, 2006 | 05:22 PM
kreionic's Avatar
Either spot is a accurate source. Theres no reason to try and switch.
EvoIX Guy check your pm's
doncarbone
Oct 15, 2015 09:30 PM
steven121
May 16, 2010 01:56 PM
YoungEvolution
33
Dec 22, 2009 08:57 PM
george3
32
Sep 28, 2008 05:33 PM
george3
Sep 24, 2008 01:48 PM
