Independent Home Dyno Results
Originally posted by 2003OZ
I jus ordered the road dyno! I hope it works as well as you guys said. It should be fun to tinker around with, if nothing else.
Let us know how it works out for you!
Speedlimit............
hey speedlimit, just go t this thing and was wondering what method you used to hook it up to the evo? ecu tap, plug wire? I have a 03 lancer and I'm not sure how to hook it up. no visable plug wires, not sure which wire from ecu? got any advice? thanks ~Shawn
What did you put in for drivetrain losses? Seems as this number could be used to fudge your results pretty easily.
Also, did you test your car in 2nd as well? I'd be curious to see if the dyno results overlay (they should).
you only use that if you want it to calc BHP..
Re: Independent Home Dyno Results
Originally posted by xtnct
Drag Coef.: 0.36
Frontal Area: 2.318 m^2
R/H: 64%
Baro: 30.05 In
Elevation: 20m
Drag Coef.: 0.36
R/H: 64%
Baro: 30.05 In
Elevation: 20m
The dyno is xtnct's and he has the inductive pick-up which is simply clamped onto a spark plug wire.
Speedlimit.....
Re: Re: Independent Home Dyno Results
Originally posted by Seņor Info
Can you explain how you determined each of these variables? That's a pretty precise frontal area (within one square mm?). Isn't that the drag coefficient for the base Evo (without the big wing)?
Speedlimit......
xtnct
For Sale - Miscellaneous Automotive
Jul 30, 2011 08:38 PM
importdps
EvoX 'For Sale' Suspension / Brakes / Handling
84
Jul 4, 2011 08:22 AM
importdps
Evo 'For Sale' Suspension / Brakes / Handling
15
Nov 11, 2010 02:00 PM
