Rubbing noise?
Old Sep 4, 2006 | 08:08 PM
MuslimEvoFreak's Avatar
Question Rubbing noise?
Hey guys, I just got my alignment 2 days ago and ever since then my car has been making a rubbing noise in the rear right tire. I took the tire off to see if anything was stuck but everything seems perfectly fine. I can't seem to figure it out. When I accelerate, it doesn't make the noise until I get to about 40 and then when I slow down to about 20 the noise goes away. Any help would be appreciated.
Old Sep 4, 2006 | 08:19 PM
EiEVO's Avatar
is it a roaring noise kinda like humming? Maybe sound like loud tire noise?
Old Sep 4, 2006 | 08:21 PM
Yea it is a roaring hoise like humming. I am sure it isn't the tires because before the alignment, I never heard this noise.
Old Sep 4, 2006 | 08:41 PM
EiEVO's Avatar
Well i asked you if it sounded like tire noise because i wanted to get a good idea what issue your having. It seems to me like you have a wheel bearing going out. Jack up the rear on both sides so the tires are off the gound and check for bearing play. Try to move the wheel/tire in and out "vertical and Horizontial". You will have to pay real close attention. But if you get ANY play at all then you need to replace the wheel bearing. I had to replace my driver rear bearing and their not cheap.
Old Sep 4, 2006 | 08:42 PM
EiEVO's Avatar
I made a quick picture and hosted it to kinda give you a idea what i am talking about. Hope this helps you.
Old Sep 4, 2006 | 08:44 PM
Alright thank you very much. I will figure this out tomorrow morning and post to see what I have found out. I am still stock and have warranty, the dealership should cover this correct?
Old Sep 4, 2006 | 09:01 PM
EiEVO's Avatar
Well, prolly not. Cause its a wearable item. Just like brakes... they dont cover that either. Now if it was a axle or anything else. they would. Who knows they may cover it but i highly doubt it. The bearings you can find online that are OEM bearings for around $180.00 Still about $50.00 cheaper than my local dealer wanted one for.
Old Sep 4, 2006 | 09:03 PM
EiEVO's Avatar
Keep in mind... YOU MAY NOT SEE ANY MOVEMENT BUT YOU SHOULD FEEL IT. ITS A GOOD IDEA TO HAVE SOMEONE LOOK BEHIND THE WHEEL AT WHERE THE AXLE GOES INTO THE HUB/BEARING ASSEMBLY TO HAVE THEM WATCH FOR ANY MOVEMENT. AS YOU TRY MOVING THE WHEEL.
Good luck.
Old Sep 4, 2006 | 09:05 PM
Will do man first thing tomorrow morning with my dad! How long am I able to drive on a bad bearing?
Old Sep 4, 2006 | 09:09 PM
EiEVO's Avatar
Well to be honest its prolly just started going bad. But if you can see and or feel quite a bit of movement then i would not push your luck. Get it replaced a.s.a.p. I drove on mine for about 200 miles after i noticed some noise coming from it. But then again i didnt have much noticeable play out of it. Just had the beginning noise. At all cost... DO NOT drive it at higher speeds like 55 + MPH cause it will just get a lot worse real fast. And you dont want it to come apart. At higher speeds its obviously moving faster and it is under more stress and it will heat up and can come apart.
Old Sep 4, 2006 | 09:15 PM
Damn I needed to take my parents to Chicago tomorrow and then the airport. So I shouldn't go over 55 mph on highway right?
Old Sep 4, 2006 | 09:20 PM
EiEVO's Avatar
I dont suggest it. Its not worth the risk... Just take my word. It may not be your bearing. But if it is your just going to cost yourself a lot more money and risking your life. If a wheel bearing comes apart at highway speeds then it wont be pretty. The noise you hear does it go away when you let off the gas or when your turn left and right?
Old Sep 4, 2006 | 09:21 PM
Yea the noise goes away when I let off the gas pedal. Then when I push the gas pedal again, I can hear it. As I go faster, the noise gets louder.
Old Sep 4, 2006 | 09:24 PM
EiEVO's Avatar
Does it go away when you let off the gas at any speed?
Old Sep 4, 2006 | 09:25 PM
yup
