Oil pressure and temp fitting number confusion
Old Sep 19, 2006 | 07:41 AM
mdosu's Avatar
I think I'm confused...
Are the following correct?
BSPT=PT
1. The oil pressure sensor attachment on the Evo is 1/8PT.
2. The oil temp sensor attachment on the Evo is 1/8 NPT.
Old Sep 19, 2006 | 08:44 AM
kreionic's Avatar
There both 1/8 NPT. The pressure is a female adaptor and temp is sending unit
Old Sep 19, 2006 | 08:49 AM
jhanksevo's Avatar
go to 42 draft designs they have the fitting and its cheap thats where i got mine
Old Sep 19, 2006 | 08:59 AM
mdosu's Avatar
okay...
so both are 1/8 NPT attachment.
I'm getting the Defi-D's pressure gauge which is a 1/8 PT sender...you sure this is the right part I need?
http://www.42draftdesigns.com/product/42902.htm
the way they worded it, it sounded like Evo was 1/8 PT and you would need the part for a 1/8 NPT sender
Old Sep 19, 2006 | 09:12 AM
kreionic's Avatar
It should work but I am not 100% that the SW sending unitd will work with non SDW gauges
Old Sep 19, 2006 | 09:36 AM
EnJaNir's Avatar
It depends on what gauges/sendors you get
Old Sep 19, 2006 | 09:44 AM
talentsearch301's Avatar
contact
he sells them for different gauges
Old Sep 19, 2006 | 09:51 AM
contact 2kjettaguy
I think his company is called 42 draaft designs
