Dyno sheet posted - 317 wheel HP! 287 ft lbs
That graph does not look right. The torque keeps rising to the peak of 287. But the horsepower drops off 5k rpms. It doesn't fit in with the horsepower torque equation.
Well the equation for horsepower is:
Horsepower = Torque * RPM / 5252
If torque was constant the horse power would go up linearly. If torque is increasing the horsepower will increase as well. Horsepower should not drop off as torque increases.
If we plug in the numbers:
287 at around 6500 rpms you get 355 hp.
Something just doesn't look right. Please correct me if I'm wrong.
Take another look at it and see if you can make sense of it - its confusing b/c their printer was running low on blue ink so the colors are off a bit
Re: Dyno sheet posted - 317 wheel HP! 287 ft lbs
Originally posted by Alfriedesq
Yesterday's dyno sheet is up and posted on my web page
Why do the torque and HP lines cross at 5750 rpms? Mathematical point of intersection should be 5252 rpms. Something is out of synch here. Correction factors perhaps?
He has about 260lb-ft @ 6500 which equals 320hp @ 6500.
So the dyno sheet is accurate.
Re: Re: Dyno sheet posted - 317 wheel HP! 287 ft lbs
Originally posted by jfh
Al,
Al,
Re: Re: Re: Dyno sheet posted - 317 wheel HP! 287 ft lbs
Originally posted by Ryan Autry
Because the scales for HP & TQ on each side of the dyno sheet are different.
Originally posted by bryans2k
Anyone else see the puff of smoke come out of the exhaust in the video?
bryan
bryan
Originally posted by Zeus
So where are the pictures of the fit and finish of this intercooler?
They are at the bottom of the page
They are too dark you really can't see it that well - but you can get the idea of how the intercooler changes the apperance of the front of the car at least
Originally posted by ADMstunna
what changes where made with this dyno run resultingin 317 as compared to your recent post of 290 something? what boost are you running?
i thought you said deleting exahust didnt make power? what boost?
Also - the bigger fmic plays a part in the power increase also
And at the same boost point it does not make any extra power - the deletion of the exhust allowed me to raise the boost
This was at 150 KPA'a falling down to 135 KPA's
scottatyamaha
171
Feb 18, 2007 07:54 PM
