Car Starting by Itself
Old Oct 1, 2006 | 04:33 PM
bullfrg's Avatar
Ok guys I have a real problem with my Evo, the car is trying to start by itself. I was doing an autox yesterday and I came in from one of my runs the car was making a terrible noise so I shut it off. As soon as it was off the starter just kept trying to start it again, finallly we disconnected the battery to keep it from doing it. A few minutes later we connected the battery again and it was not doing it, so I drove the car home. No issues for the 2 hour drive but after the car had sat in the garage for 4-5 hours it started doing it again. Starter would just run and the car would start turning over with no keys in the car or anything. Please help
Old Oct 1, 2006 | 04:36 PM
BretTheJet26's Avatar
ghosts?
Old Oct 1, 2006 | 04:39 PM
WrX Kila's Avatar
You may have the Knight Rider version of the Evo!
Old Oct 1, 2006 | 04:44 PM
3SgteGuru's Avatar
Starter Selonoid, when its doing that check to see if power is Present at the Selonoid Sinal Wire, If so Then ITs a Short, If not Change the starter.
Old Oct 1, 2006 | 04:58 PM
EVO-8-Nate's Avatar
Kerby has now taken control of your EVO. Get it in a movie and make millions.
-Nate
Old Oct 1, 2006 | 05:08 PM
Mitchubishievo's Avatar
I'm going to have to go with the "your car is possed" route.......although the answer above mine "seems" more realistic. How much cooler is it to say that your car is possesed though!
Old Oct 1, 2006 | 05:14 PM
bullfrg's Avatar
Not much fun so far it keeps killing my battery
Old Oct 1, 2006 | 05:15 PM
caligula's Avatar
starter solenoid if part of the starter,you might have to replace you starter,in the other hand you have the starter relay maybe the relay is binding up,sticking at times check that out too.good luck and no is not posses lol lol .
Old Oct 1, 2006 | 05:17 PM
caligula's Avatar
swap relays see if it stop's if it does then u know u have a bad relay.
evolusion's Avatar
where can i buy this kit
Old Oct 1, 2006 | 05:28 PM
caligula's Avatar
^^ wtf ?
EVO-8-Nate's Avatar
Starters aren't that expensive just replace it and call it a day.
-Nate
Old Oct 1, 2006 | 05:30 PM
3SgteGuru's Avatar
I Agree with the Realay theory too, so when its doing that Starter thing pull the Relay. Your gonna need a new starter soon anyway at this rate a new batery too. (next up Altenator) Soo you should fix this ASAP.
Old Oct 1, 2006 | 05:32 PM
evobeatsti's Avatar
hey do you have a white evo now because you hit a deer or something in your blue evo, i go to a lot of the utahscca events and i think ive seen you on the forums before...
Old Oct 1, 2006 | 05:35 PM
3SgteGuru's Avatar
^^ dude What are you Talking About. There is something Called PM. You don't have to post that to confuse every one. Man My IQ is Low and I have ADD your not helping.
