setup for my evo
Old Oct 5, 2006 | 08:48 PM
evobeatsti's Avatar
setup for my evo
ok so i have about $7000 to spend on my car coming up in about a month or so, i already have tbe and sway bars. i want a pure daily driver car because it is the only car that i own but here was the setup i was thinking. 272 cams (possibly 272i/264e) warlboro fuel pump, arp head studs the new buschur 20g turbo w/ ams front mount. uicp and licp w/ mini battery. oh and cobb accessport w/ custom tunes for 91 octane daily driving and map for leaded race gas. then for suspension i would get some form of either muellerized or robispec coilovers, i already have wide wheels and tires. am i missing anything from this that i should add, i dont want to do alchy or meth. this car would be a every day daily driver + i would autocross it a lot and road race it about 5+ times a year. anything else i might need?
Old Oct 5, 2006 | 08:52 PM
Lancematic's Avatar
you will do much more damage running leaded race gas vs alchy or meth. I would do the meth injection with a failsafe. Also if you have that much why not a 50 trim?
Old Oct 5, 2006 | 08:54 PM
xXxJIGGAxXx's Avatar
Sounds good to me........but 7g's is alot of money. I would put it somewhere other than my evo if I had it.
Old Oct 5, 2006 | 08:55 PM
evobeatsti's Avatar
i dont want a 50 trim because i want a turbo that spools as quick as stock, im not looking at big power here but a large power band, + the 50 trim cost like $4300 while the buschur turbo is like $1700 which is a big diff
Old Oct 5, 2006 | 08:56 PM
evobeatsti's Avatar
all of it probably wont go into the evo im just saying that $7000 is my limit, that i wouldnt spend over that amount of money on the car
Old Oct 5, 2006 | 08:57 PM
GT35REVO8's Avatar
go big or go home 35R!you can build a daily driver 35R for about 9-10Gs...mine is a daily driver
Old Oct 5, 2006 | 09:09 PM
BBYBruno's Avatar
Your a smart person.
Old Oct 5, 2006 | 09:14 PM
evobeatsti's Avatar
see the thing is that i dont want to blow 9-10g's becaise i definately dont have that much plus i want to have this be an excellent autocross car because that is what i do mostly in the car and a gt35r would be terrible for autocross that is why i want to stick with something small and cheep like the 20g
Old Oct 5, 2006 | 09:19 PM
evobeatsti's Avatar
would i gain more power with larger fuel injectors on this setup like some 680's or 780's? are there any other parts im leaving out?
Thank you, I learn from my mistakes, as in a 280 whp Ford Contour. Edit: other than that i would no longer put any sort of significant money into a car. There are far more important things I would invest in.
Old Oct 5, 2006 | 09:25 PM
PKEVO8's Avatar
dont forget a new clutch. If you autcross it, then maybe get some pads and ss brake lines as well plus brake fluid. if you can use a 20g without new injectors then i would do that. saves you a bit of mpg for daily driving. If i had to, then i'd prolly go with 680's.
Old Oct 5, 2006 | 09:34 PM
wroblewskievo's Avatar
the alky kit is not good for road racing. i was talking to martin at ams and pretty much a tank of alky would last about 10 minutes on a road course. he did mention getting a smaller nozzle and turning down the boost so the alky would last longer. good luck on your mods.
Old Oct 5, 2006 | 10:03 PM
Turd Squirter's Avatar
If it's a daily driver, you're going to use pump gas, and you're going to occasionally autoX might I suggest the following...
Walbro 255lpm: $100
264in/264ex cams: $400
cam gears: $200
720cc injectors: $350
new headstuds & headgasket: $150
organic clutch/flywheel combo: $500
Billstein PSS9 coilovers: $1600
20G IX turbo & conversion kit: $1600
You'll have enough money left over for installation, tuning, and tires. BTW I don't think COBB has released their accessport for the Evo yet. You have plenty of options though...ECUplus, EcuTek, etc.
Old Oct 5, 2006 | 10:12 PM
Top_End_EVO's Avatar
pfft gt35r is childs play-- go with at least a 67mm compressor housing. gt37 and up for the win!!
Old Oct 6, 2006 | 08:35 AM
Ang Wen Yan's Avatar
ECUFlash with tuner of your choice
BR intake
Walbro pump
ARP Headstud
GSC/BC cam
Forge/1G DSM DV
FMIC kit
Ebay 02 housing
Ported Stock/Full-Race Exhaust Manifold
Alky
Coilover of your choices,but i will do KW V3 since it is best bang for buck
Runing race gas will clean your engine,but burn 02 sensor.Top End EVO,he want an autocross car,not a drag car.xXxJiggaxXx,did you have hobby???Modifiying car and racing car is a hobby,not invesment + you can't bring the money when you die.Just spend the money you have when you have chance and keep some in bank.Invesment is too risky,you can gain and lost money and you will not enjoy invesment.
