clutch question
Old Oct 8, 2006 | 12:12 PM
ohthree's Avatar
clutch question
I have about 25k on my stock clutch. When I go into 3rd gear or 4th gear and then go WOT, the revs stops, and then continues. Is this the clutch slipping?
Old Oct 8, 2006 | 12:50 PM
Waz996's Avatar
clutch slip: the revs should go up all the way and u feel the car is not goin with it..
ure describing totally the opposite?
Old Oct 8, 2006 | 01:01 PM
Compjoc's Avatar
Do you have a boost gauge? How high are you boosting when the revs stop?
Old Oct 8, 2006 | 01:37 PM
3SgteGuru's Avatar
Maybe your Expeirencing The Motor Hop, Possibly because you letting the Clutch Out Fast. The Stock Evo Motor mounts are Soft, But an Engine Dampener fixes that.
Old Oct 8, 2006 | 05:00 PM
ohthree's Avatar
its not when i shift. when i drive i go under WOT and it feels like my revs go up and the car doesnt hold. someone suggest clutch slip or my throttle plate was off or something.
Old Oct 8, 2006 | 05:05 PM
joseph143's Avatar
does the car slightly free rev first. My clutch before it went out would slip and jump about 2k and then grab again. also after it would grab the rpms would wavier a little. meaning they would not be constant they would go up a lil and then drop a lil. even at wot. Of course my clutch was toast at that point yours my not be that bad yet
ohthree's Avatar
i would downshift to 3rd, and then floor it, and the car would make a slight popping sound and then hold at that rev and then keep going. eh im confused...
Old Oct 8, 2006 | 05:06 PM
ohthree's Avatar
also im not sure what im boosting.
Old Oct 8, 2006 | 05:12 PM
ohthree's Avatar
i have an extra stock clutch so its not a problem i just want to make sure thats the problem because clutch installation is expensive.
Old Oct 8, 2006 | 05:26 PM
joseph143's Avatar
if it pops and the takes off... and only at wot... you sure thats not a bad tune... sounds like a detonation. you might try running higher octane first... i mean its just a shot. I have never heard a clutch react like yours.
Old Oct 8, 2006 | 08:39 PM
ohthree's Avatar
i dont daily drive the car so i'll have it looked at. i might just be doing a ****ty job describing it but the car has no tune and all the mods in my sig. waiting for E FLASH.
i basically floored it and at about 4k the revs cut and then continued going but it was very noticable like iwas taking my foot off the gas altogether.
Old Oct 9, 2006 | 09:34 AM
evofabulous's Avatar
sounds to me that you are maybe hitting fuel cut. on your signature it says that you are pushing 21-22 psi and you say you arent tuned. i had the same problem when i turned my boost up that high. the car jerked really fast like i let off the throttle and then slammed it back down really fast... try turning your boost down to 20 psi and try it again maybe that can fix your problem
Old Oct 9, 2006 | 09:40 AM
Rob W.'s Avatar
Yeah, sounds like fuel cut due to too much boost. You need a tune to disable that 'feature'.
Old Oct 9, 2006 | 09:44 AM
Mortis's Avatar
Agree. Sounds a lot like fuel cut to me now. My car was the same I think as what you are describing. I had a full exhaust and intake, put the boost up to 21 psi, and when I first really got on it, just as the fun was starting to happen, BOOM, nothing, total cut out. Feels like you hit a wall a bit. Everything just stops for a second, then comes back on.
If that's what is going on, it's fuel cut. Get a tune, and have it removed, and you'll be good to go.
Old Oct 9, 2006 | 09:56 AM
3SgteGuru's Avatar
hmm Sounds funny, maybe you can have a proffesional look at the car. Someone who knows what they are doing. Be sure to post a Fix i realy wanna know whats wrong. Good luck
