Stroker Kits
Old May 17, 2003 | 07:36 AM
hornet's Avatar
Originally posted by Claudius
Hi
If you just want the stroker and not increase the boost much, then you dont need anything else except a slight remap.
If you want to use the stroker kit to use a bigger turbo and make more power, you'll need a stronger head gasket, head bolts, camshafts, a fuel pump, injectors, etc.
OT-I noticed your signature just now. Is that 1050 bhp in your Evo?
Old May 17, 2003 | 10:44 AM
hornet's Avatar
Hey, that's still great I wish I had 400 bhp in the one Evo I have....
Old May 22, 2003 | 06:13 AM
Maxxy's Avatar
Originally posted by rdrkt
I have a 4g64 in my DSM with a Garrett 60-1 stage 3 wheel and .82 ar exhaust housing it spools up that big turbo like a pin wheel.
ShapeGSX: Why not just use a 7bolt 4g64 crank? It isnt ideal as far as r/s ratio goes but I think it would be easier than getting a whole 64 block in there.
I know this is newbie question , but still, where could I ask for 4G64 block or crankshaft, which model originally uses that block ?
Thanks.
Old May 22, 2003 | 06:21 AM
ShapeGSX's Avatar
The 4 cylinder Eclipse uses the block. So does the Galant. Actually, it is used in lots of Mitsubishi cars.
The only issue is finding out whether the head and block will bolt up, and which headgasket will work. I'm certain that the block and head will bolt together. But sometimes not all the oil and coolant ports line up perfectly with the head gasket.
Old Dec 2, 2003 | 09:21 PM
spdfrk434's Avatar
Originally posted by value
I've been to their shop and watched them making them. Same goes for Tomei making cams. 60 year old guys who been doing nothing but making engine parts all their lives. Jun is one of the most respected tuners in Japan. How could they put their name on a stock crank and expect it to handle 600-700 hp some of the tuners run over in Japan.
Don't underestimate the power of a stock DSM crank. John Sheperd is laying down 8 second runs on a stock crank with an estimated 850whp.
www.shepracing.com
Old Dec 2, 2003 | 09:47 PM
5StarSuzuki's Avatar
In Timeout
HP is HP
2.0L makes more power than 2.2 Stroker.
2.0L makes more power than 2.4 Block.
Old Dec 2, 2003 | 09:56 PM
umiami80's Avatar
Short stroke, means high HP but less torque, as you stoke, the opposite is true.
Old Dec 2, 2003 | 10:15 PM
en1gma19's Avatar
That money would be better spent buying better internals (same size..2.0L), and a stand alone so you can rev up to 9k. That would probably give at least as much hp if not more, plus you don't lose as much torque.
Old Dec 3, 2003 | 02:45 PM
artinist's Avatar
keep in mind that a larger displacement brings into play other issues that one has to keep in mind.
the fuel system and especially the head will need upgrading due to the larger volume of air flowing throw the ports. a professional head port job will be a must to take advantage of the larger displacement.
its something for more of a hardcore racer to do. it should be placed towards the buttom of the things to do list.
the effort would be much better spent on a better intercooler and turbo to increase boost to higher levels.
Old Dec 3, 2003 | 03:13 PM
maki's Avatar
Originally posted by ShapeGSX
I just found a link that shows that the JUN stroker kit for the Evo is really just a reground stock Mitsubishi crank. BAD idea.
Old Dec 3, 2003 | 04:45 PM
ShapeGSX's Avatar
Originally posted by maki
Hey, way to roll eyes at something I wrote back 7 months ago and corrected later on that day on the same page! You the man!
Old Dec 3, 2003 | 04:48 PM
LancerEvoMR's Avatar
Argh. Newbies. Closed.
assembeldbygod
118
Nov 3, 2010 06:05 AM
benderrodriguez
13
May 27, 2010 03:56 AM
richysevo8
100
Mar 2, 2008 08:19 AM
spooledevo
Jun 20, 2006 07:29 PM
ruthless evo 8
Sep 14, 2004 01:57 PM
