The "defective" '05 coolant line?
Old Oct 16, 2006 | 06:30 AM
3SgteGuru's Avatar
Just cause the line breaks doen't mean you need a whole turbo, lol.
Old Oct 16, 2006 | 07:16 AM
DanJ's Avatar
Originally Posted by alloyic_rs
maybe this is why my evo was blowin white smoke from the exhaust when i bought it? not sure if it still does it but i know it did. or does the recall have nothin to do with my situation.
This is not the cause. this would only cause smoke to come from under the engine bay, not the exhaust.
Old Oct 16, 2006 | 10:18 AM
Liqquid's Avatar
So is it just the rubber section??? or does the metal part have some sort of defect?
Old Oct 16, 2006 | 10:55 AM
Kee1pride's Avatar
yahuh!
Old Oct 16, 2006 | 11:01 AM
STIGOD's Avatar
bump
Old Oct 16, 2006 | 11:02 AM
KOEvo's Avatar
The recall was only for certain Evo's and based on your VIN you may or may not have to take your car in for service.
I called, and my VIN did not land in the defective units...
Old Oct 16, 2006 | 11:04 AM
DRFTKNGG's Avatar
I didnt even know there was a recall. I was smelling coolant one day, traced it to this coolants line you guys are talking about. It was starting to swell, looked like the rubber is weak. Had a bubble like it was about to burst! Nasty mess if it did.
Old Oct 16, 2006 | 11:46 AM
alloyic_rs's Avatar
hey i just did my 30k service and after i picked up my car i really smelled some coolant, is it normal to smell it after its flushed? or do yall think i need to ask about the recall for my evo
Old Oct 16, 2006 | 01:05 PM
EVOIX4me's Avatar
Mine is leaking , not sure what hose its coming from very hard to trace it , you can smell the coolant leak. Mitsu replaced mine about 6 months ago , however its leaking again . Not sure if they will fix it for free this time ?
Old Oct 16, 2006 | 01:53 PM
Ph3n1x's Avatar
Already replaced mine, wasn't hard to do.
Optional:remove Intake pipe.
Remove BOV
Remove top section of IC pipe
Remove Top Radiator Hose
Remove Turbo Coolant hose
Replace
And reverse
45mins tops and doesn't require mechanical skills.
Cost 7 dollars at the dealer for the replacement hose.
Old Oct 16, 2006 | 01:54 PM
Ph3n1x's Avatar
Prolly residual coolant from the soo called flush on the motor that got cooked from the heat. Will go away sooner or later.
Old Oct 16, 2006 | 03:55 PM
Liqquid's Avatar
WTF? replace the defective part with another one?
Old Oct 16, 2006 | 03:56 PM
Liqquid's Avatar
Remove BOV
Replace
And reverse
Nice! that's what I was wanting to know.... Thanks!
Old Oct 16, 2006 | 05:24 PM
EVOIX4me's Avatar
Yea tell me about it , bastard mitsu techs
Old Oct 16, 2006 | 07:14 PM
D-machine's Avatar
I received the letter in the mail that mine was one of the recalled probably about 8- 9 months ago and they replaced it in about 1/2 hour.
