Evo 9 probs. please help
Old Oct 21, 2006 | 01:08 PM
Chino1's Avatar
i got into my car this morning to go to the gas station because my gas light has been on since last night. im driving to the gas station and about half way there my car starts acting funny:
while driving as my car goes into boost right around 5psi it starts sputtering, the car itself starts stuttering and i see black smoke blowing in the wind out of my exhaust, so i keep puttin' it to the gas station and filled up hoping my prob was because i was extrememly low on gas. well after i fill up i start driving back home but its still doing it so i start testing it in each gear to see what is going on and in each gear as soon as i get anywhere between 3-5 psi it starts sputtering and the power feels like the turbo is doing exactly the opposite of what its supposed to do. (if you could imagine that) basically as soon as i start making boost it does a little nose dive, but you can still hear boost rising. but the car doesnt want to react to it. so i finally throw a CEL and went to check it, it threw a code of P0134 which is O2 SENSOR CKT NO ACTIVITY (BANK 1 SENSOR 1)
after that i opened evoscan and did a check for my self and this is what i got
Updated: 12:01:24
Vehicle speed sensor
Barometric pressure sensor
Knock sensor
Injector circuit
EGR sensor
did it again 15 mins later
Updated: 12:15:29
Knock sensor
Injector circuit
Fuel pump relay
anyone ever go through this before? please help me out guys.
Old Oct 21, 2006 | 01:13 PM
PA-silver03evo's Avatar
Sounds just like you have a problem with the front 02 sensor. I am assuming you checked the codes with evoscan while the car was running. If you do that, it reads all those codes out. You have to check it with the key on but engine off. If the car is near stock just take it to the dealer.
Old Oct 21, 2006 | 01:19 PM
EVEHO9's Avatar
take it to the dealer hopefully theyll fix it
Chino1's Avatar
yea i did read those codes while it was running. i'll go out and check em again the right way... my car has a few mods
BR TBE
megan racing exhaust manifold
injen Intake
injen ICP
MBC
dynoflash tune
Old Oct 21, 2006 | 01:24 PM
RoadSpike's Avatar
BR TBE
injen Intake
injen ICP
MBC
dynoflash tune
Sounds sorta like missfire to me
Some people have posted that in boost they have missfire with bad plugs, wires
Just a couple ideas for you
Old Oct 21, 2006 | 02:44 PM
Chino1's Avatar
went out and got my hands dirty... i found the prob, it was a big boost leak, basically i wasnt recirculating from the intake. thanks for all the responses, i can always count on
Evo-m.
Old Oct 21, 2006 | 05:42 PM
When I first read your symptoms thats exactly what I was going to say because if you have a major boost leak, thats exactly what would happen but I was thrown off when you said front 02 sensor code. Anyway, glad to hear its fixed easily.
Old Oct 21, 2006 | 05:55 PM
Schuyler's Avatar
If it was running too rich - aka a "huge" boost leak - he may have fouled his 02 sensor.
Old Oct 21, 2006 | 11:19 PM
Chino1's Avatar
thats exactly what happened schuyler but the CEL hasnt came back on and i been driving all day so i think its safe to say that the sensor is ok...
Old Oct 22, 2006 | 06:02 AM
Schuyler's Avatar
Good thing - those puppies are expensive!
Old Nov 17, 2006 | 01:24 PM
Spool's Avatar
The car did the same thing to me once, but you found the probem on your own. When it did it to me, the BOV came off of the intake pipe. Keep an eye on it.
christianreed91
Sep 11, 2016 09:12 PM
SpeedLimit55
28
Dec 23, 2015 02:27 PM
Skyzo
Oct 17, 2012 06:39 AM
BadazzCR
Aug 23, 2008 07:40 AM
