Need For Blow Off Valve?
Originally Posted by phillman332
I had a question, I was thinking of getting the GFB Stealth BOV and I was wondering if that would hurt performance as well?
Originally Posted by thisxguy
there are ONLY 2 uses for a BOV.
1) you want the Pshhhh sound, which hurts the performance of your car
-Josh
Originally Posted by battlecattle
You need to stop talking...or explain completely what you mean. Because what your saying is ALL EVOS lose power with a BOV which is false. Mine does just fine.
-Josh
-Josh
No you think it does just fine but in actuality its not. Read up man this subject been beat every way possible. Don't VTA on a maf equiped car PERIOD
Question: Since I'm running low boost (23 psi) should I need to upgrade my IX DV??? I got the Forge EVO15 but am comtemplating about install it because I've heard aftermarket DVs give partial-throttle problems (fluttering??) which will effect my daily driving.....
People should not be upgrading their stock IX DVs unless they are running huge boost or an upgraded turbo. I don't know what's going on here.
Battlecat, you're getting confused about the terminology. He said BOV, which technically refers to a VTA valve. You are thinking he means any valve, whether it be a diverter valve or vta. VTA = BAD. DV = GOOD. Sometimes, we refer to both of them as BOVs to save time.
Originally Posted by v8k1ller
Would it hurt to change the stock IX DV running 23 psi other than our wallets???
To the OP.
Are you asking for a good Diverter Valve/Compressor Bypass Valve/Recirculated BOV that can replace the stock one - be just as good under stock boost and stock ECU as the OEM IX and give you a good sound and has headroom for more boost down the road?
Does such an option exist?
Improperly set up CBV's can flutter. If you are running 15psi and you have a spring designed to run 20psi+ the valve will have a hard time opening which could cause flutter.
The Evo15 valve comes equipped with a blue spring that covers 85% of Evo applications including 23psi. For 25-26+, move to the red spring.
Evo IX's on 93 tuned properly can be run to spike 24-25psi on pump.
ALL evos don't have MAF..PERIOD! I am not talking about DV. Don't lump everyone together.
If you're asking the question, the answer is 100% "yes, it's bad, don't do it".
No I am not asking a question I was informing people that VTA is not bad on ALL EVOS which was previously said. Just for the person that said that to correct their post to say that all cars with a MAF.
Originally Posted by TTP Engineering
23psi could be hit or miss with the IX valve. You are starting to reach the limit of what is can hold.
sweet !! the forge evo15 is a good deal!! everyone get on it before it's too late!!! get it from TTP Engineering those guys are the best!
