question on tbe and tune
Old Oct 27, 2006 | 10:30 AM
zeus1's Avatar
so i received my tbe. right now my car is tuned on the stock exhaust. i plan to have a re-tune done to accomodate the tbe addition. i cannot get a re-tune until roughly two weeks. my question is if i install the tbe now with the car tuned on the stock exhaust will this cause problems? it is tuned with a mbc set to 22-23~spike tapering to 20psi
Old Oct 27, 2006 | 10:34 AM
Kronik's Avatar
No, it will not cause any problems. You will be fine.
Old Oct 27, 2006 | 10:37 AM
boomn29's Avatar
Put it on!
Do the poor man's reset to the Ecu; it'll help. Bascially unhook the battery for a few minutes, and pump the brake pedal a few times. When restarted the car will 'learn' a little and adjust.
Make sure to watch your boost levels at first! With the free-er flowing exhaust you might over-boost. If so, just back down the MBC a little to be safe until your retune.
Old Oct 27, 2006 | 10:38 AM
zeus1's Avatar
will the cel light kick on by unhooking the battery?
Old Oct 27, 2006 | 10:44 AM
Kronik's Avatar
No the cel light will not kick on by unhooking your battery.
Old Oct 27, 2006 | 10:45 AM
DanJ's Avatar
Nope, it won't effect the CEL.
Old Oct 27, 2006 | 10:51 AM
zeus1's Avatar
how long should it take a shop to install a tbe?
Old Oct 27, 2006 | 11:02 AM
tony_b's Avatar
took me about an hour with a jack and hand tools. Most of the time was used by taking off and reinstalling the undertray...
Old Oct 27, 2006 | 11:10 AM
icecream6's Avatar
i hate that undertray cause the little plastic bolts kept snapping when i was putting it back on
Old Oct 27, 2006 | 11:22 AM
Warrtalon's Avatar
It shouldn't take 2 weeks to get a retune if you have EcuFlash. Just send in your ROM and have it adjusted by the tuner (or by a tuner on here).
Old Oct 27, 2006 | 02:27 PM
zeus1's Avatar
i had it customed tuned originally on a dyno by a guy near me so i need to wait...i dont mind waiting just wanted to make sure the car would run ok in the interim
Old Oct 27, 2006 | 02:35 PM
Warrtalon's Avatar
It will - no problem.
