Engine Mounting & GT30R
Old Nov 7, 2006 | 06:44 AM
Endless_818's Avatar
Hi guys,
would really appreciate if somebody out there able to tell me if E7GSR engine mounting can fit to E8GSR nicely without any modification. One more issue anybody out there using garrett GT30R??Will my stock piston & conrods able to tale the stress n at what boost will it be a safe bench mark??Cheers!!
Old Nov 7, 2006 | 06:52 AM
okevolutionVIII's Avatar
Dont know about the mounts, but Im pretty positive that they will work. A GT30R the pistons and rods will hold, but race gas or pump+meth and a safe tune will be needed to max it out. The turbo blows a little over 30 psi and is capable of over 500whp.
Old Nov 7, 2006 | 06:53 AM
Ev0cRaZy's Avatar
A friend of mine is running 30psi w/ meth and headstuds everyday on stock block, and no problem
Old Nov 7, 2006 | 06:57 AM
Headstuds are definetly needed for that boost, but I only ran 20 psi when I had mine. Kind of wish I still had it.
Old Nov 7, 2006 | 07:20 AM
but what about on pump gas?? Was thinking of swapping a engine from e7 to e8. was been told that if on stock pistons & conrods, the max i can boost will be 1.2/1.3bar. They say if on a 8mr even on stock can easily boost at 1.5bar but nt on the e8gsr block. N again for the gt30r i believe its a waste if only boost at 1.5 n let alone 1.3bar, dnt u guys think so..
Old Nov 7, 2006 | 07:30 AM
You may be able to get around 380whp on pump gas on 1.5bar in which the stock turbo would need race gas and 2.0bar to make similar #'s so it is worth it.
Old Nov 7, 2006 | 08:07 AM
Ev0cRaZy's Avatar
If your going to get a GT30...Get Injectors,Meth Injection, and Head Studs...And a Good tune! Then youll be moving along
Old Nov 7, 2006 | 08:15 AM
Is running with meth necessary?? Got the hks 680cc injectors, fuel rail, 255l fuel pump & a surge tank c/w external pump. The head was totally done up. Using hks prototype cams & cams pully, titanium retainers, valve & springs. Port & polish as well. The only issue will be the internals. ppl are saying that a gsr block aint ideal for that setup unless getting a 2.3 stroker kit. But for me i still believe in the potential of the original 2l engine.
Old Nov 7, 2006 | 08:17 AM
oh was going for the Motec M800 ecu for the setup as well.
Old Nov 7, 2006 | 08:23 AM
Running meth injection is not nessesary but it is very close to running race gas without the cost. Remember, it is capable of 500whp on a stock block, it'll hold the power.
Ev0cRaZy's Avatar
Well I would rather be safe running High Boost with a $100 Mod, than blowing a headgasket and screwing up your head. if your going to run 25+ Psi then u need headstuds. I use meth cause its a great Alternative to race gas.
///M3an Machine
Oct 1, 2009 10:11 PM
zedevo
Mar 21, 2009 11:10 AM
chapter8
For Sale - Cars For Sale
38
Sep 26, 2007 08:41 PM
badboybr09
Aug 23, 2007 08:04 AM
Evo325
10
Apr 4, 2007 07:29 AM
